I am looking at a 1964 Globetrotter. The interior looks to be very original and in good condition other that the linoleum. The problem is that there are two dents in the back that I am worried about repairing. These dents are on the back panels and go into a second panel and include a seam.
How hard is it to remove the dents good enogh to polish the exterior? Do I have to worry about future leaks? Should I just keep looking for a better one before I get in too deep?
Steve
A lot depends on how deep the dent is. Unless it's really bad, it should not affect water tightness. If the Globetrotter is a decent deal, grab it and enjoy it. Some dent can give an Airstream character.
__________________ SuEllyn & Brian McCabe WBCCI #3628 --- AIR #14872 2005 25' Safari FB (Lucy) with HAHA 2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Can these be removed successfully or would I be looking at panel replacement? I am looking at this one, like it but I would like a good polished shell when I am done.
Thanks for the advice.
Steve
Hi piratesteve--To me, they add character to your A/S. I'd leave them alone, and letter OUCH on them. That will be a real conversation starter wherever you go. You can tell people who ask, about your encounter with flying saucers, who bumped into you, believing your A/S was the mother ship. The position of the bumps is just where you would expect contact from outer space. Have some fun and enjoy your A/S rather than be concerned about a little character enhancement.--Frank S
Steve, you're way ahead of the curve! You've learned to post photos by your third post!!!
I'm thinking you're going to be able to smooth out the major indentations of those beauty marks but likely not going to be able to cure the creases.
Remember that your unit is not new and some age and character (beauty marks) make it look .....well, better.
Glen Coombe AIR #8416
1984 28' Funeral Coach
Golf Professional Sales Rolling Showroom
"I'm not an expert. But I did sleep in an Airstream last night."
Do not feel alone, I have a few......wish I knew how to post pics It looks to me like the smaller one--the one on the seam basically could be pulled out.
Dillons in Apache Junction, AZ, did some of the "pulling" for me and I'm sort of good at the moment.....
Mine was hit in the right rear tail light....it dented the tail light in....they pulled it out. It is not perfect, but just wait, I'll get worse.
Kistler
Brenda
Misty (Maltese)
Maxwell (grey tabby)
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
We also have a 64 Globetrotter with a large dent in the upperleft corner. See photo below. It goes on either side of the seam. For reimbursement from the party that dropped the tree limb on it, we had several est. done. The one from the local dealer was $ 2,705.00 (two segments plus labor).
We think the frame maybe bent underneath, as we tryed the suction cup. You can't see the dent from insde and it doesn't leak....so we have continued to enjoy using it , even with the boo-boo
There's not exactly a frame under there. It has stringers and formers. There is a network of small aluminum channels that run horizontally and vertically around the body. Their function is to separate the inner and outer skins and help give form to the exterior. The strength of the Airstream body comes from all of these parts working together, and it yields a remarkably light-weight, strong body. This is what's known as a semi-monocoque construction. It's "semi" because below it is a flexible ladder (or pipe, on the older ones) conventional frame. This is just below the floor.
Anyway, if any of the formers did get damaged, they are neither expensive or difficult to replace.
I think you could probably remove the inner skin in that corner and gently push that dent out to improve it a LOT. However, if the other party's insurance is going to pay for it, you might as well get two nice new panels out of the deal.
You know that means that you'll have to polish it to make it look right after putting two new panels on it.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
64 Lawncondo,
you will have to remove the inside panel ,the upper section I think is one big piece as it is in our 60 trdwnd.you then can see the outer panel segments.
no way to suction out that dent.The seam is strong as the panels overlap
at those rivited areas.any time you have a dent like that ,some inside work
needs to be done ,it will take work ,and you cannot just pound it out .Must be carefully worked outward .I would recommend some wood tools ,like a rounded mallet head to help work the dent out ,also a short 2x4 rounded
on the end to match the curvature of the panel so as not to stretch the aluminum in the wrong way.It can be done ,patience is the key here ,as
it will take time .The idea is to move the dent back out the way it pushed in
so to speak.Any way can it look better? absolutly will look better .Panel replacement will give you a perfect repair if done correctly ,depends on what
you will be happy with ,the repair can also be near perfect if done correctly
by an experienced metal person ,its an art really to form metal .
