Old 08-04-2008, 10:57 AM   #1
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Help !!! Need Ideas for a skin repair
I want to take off what i believe is the old tv antenna. but am left with a 3/4 inch hole.. the screw holes above and below that held the bracket I am gonna put rivets in. But what to do with the big hole..
I can put the bracket back on which you can see stuck in the radio antenna. this will cover the hole and may look better than a patch...
Any other ideas!!!!!!!!!???????
There is also a newer looking tv antenna on the roof. with a crank in the roof, this one will stay, but the cord runs down the front of the trailer... Think I will just cut it since I really don't think we will use it. Any other ideas for this....
Old 08-04-2008, 11:03 AM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Do you have access to the back side? This is the limiting factor as to the type of repair.
Old 08-04-2008, 11:11 AM   #3
purman's Avatar
1968 28' Ambassador
the hole goes all the way through so I have a hole a little bigger on the inside about 1" diameter to work with. for access..
Old 08-04-2008, 12:02 PM   #4
Aerowood's Avatar
Arvada , Colorado
If you could gain access to the backside, a doubler could be riveted to the inside, with a filler used to plug the hole. If it was riveted in with flush rivets the repair would be as unobtrusive as possible. This type of repair is called a dollar dime repair in the aviation world.
Old 08-04-2008, 12:11 PM   #5
muddy_hollow's Avatar
1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
Fill it in
I would suggest cleaning up the area and then filling the holes with an olympic rivet. Then shave it down or snip it close. It will blend right in.
If you have larger holes, cut a piece of aluminum to a desired shape (round most likely) and rivet it on.
At the end of the day, these types of patches are common place and would blend right in.
HTH,
Doug
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 08-04-2008, 12:18 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
That looks more like a radio antenna but the repair is the same. I use the aluminum duct tape for a temporary repair until you decide the best way to fix it. A small square patch with sealant behind it riveted over the hole is going to be the easiest and the best patch. Use the Olympic rivets for the patch, regular pop rivets will leak thru the mandrel hole.
Aaron
WBCCI #XXXX AIR #2495
Old 08-04-2008, 12:56 PM   #7
purman's Avatar
1968 28' Ambassador
A friend suggested putting a flag holder over the hole? This might be ok just need to find one?
Old 08-04-2008, 09:04 PM   #8
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I used a piece of aluminum purchased from Lowe's Home Improvement as a patch. I cut a round circle slightly larger than the outside screw diameter of the CB antenna the PO put on my '77 Excella, drilled 3 holes to match the screw holes already there, put Sikaflex 221 on the back side of the patch, riveted them with Olympic rivets after dipping them in Sikaflex, drilled additional holes of equal spacing and then finished with the same dipped Olympic rivets around the circumference to make a nice repair. The inside round hole was taped with aluminum foil since it was hidden inside a closet.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-19-2008, 12:29 PM   #9
purman's Avatar
1968 28' Ambassador
Ok, I choose to go with the Flag pole holder, as my kids love flags and it looks ok.... It was a little bigger than I wanted but I painted it as it was white... I think it came out ok..... You can see the original hole on the first post...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Alum. Skin Repair 74Tradewind Ribs, Skins & Rivets 12 10-31-2009 01:30 AM
Skin Repair on my new Bambi! skykingpilot Ribs, Skins & Rivets 4 07-23-2007 07:44 PM
Exterior Skin Repair petemoss Ribs, Skins & Rivets 0 10-26-2006 02:49 PM
Skin Repair or Replace? MarkExc500 1978- 1979 Excella 500 1 04-04-2006 01:12 AM
Skin Repair newae Ribs, Skins & Rivets 10 03-13-2004 10:35 AM
