Old 09-11-2012, 07:08 PM   #1
2008 25' Safari
Newport , Oregon
Hehr window replacement screws
2008 Safari...I thought I'd try here rather in the window forum because I'm sure someone here has the same problem as I have.
I live right on the coast and in addition to filaform troubles, I also have rusty Hehr window outside screws that are above the portion that opens. I went to Fastenal and they measured the screws and ordered stainless steel ones that won't rust as easy. They just came in after they were special ordered, and they're too big. They sent size 8 by 5/16th's and it looks like I need 6's. Anyone? What size do I need? Where do I get stainless screws that small?
Steve97365 is offline   Reply With Quote
Old 09-11-2012, 08:00 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Fastenal should have anything you need. If they ordered the wrong screws they will exchange for you. Your on the right track, use stainless whenever work is done.
Old 09-11-2012, 08:03 PM   #3
Kevin245's Avatar
If you are looking for tapping screws McMaster-Carr has them.
McMaster-Carr
Eleanor Roosevelt
