Old 08-01-2016, 03:29 PM   #1
1967 22' Safari
AMARILLO , Texas
Has anyone painted their A/C shroud silver or grey
I'm mounting my new Dometic A/C on my '67 Safari. It sure looks nice without the old ugly white one up there. Thought about reprinting the shroud silver or grey. Has anyone done that or seen it done? If you have, how did it work out? Surfed the net and A/S forum. Can't believe it hasn't been tried at least once!!
10brink is offline   Reply With Quote
Old 08-01-2016, 03:43 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
I did exactly that when I bought my 19' CCD in 2005. Had the body shop next door paint it in Mercedes silver, which is an exact match.
Looked awesome!
If you look at all of Airstream's Interstate vans, they all have their Dometic shrouds painted to match the Sprinter base color.
Lew Farber
Old 08-01-2016, 04:13 PM   #3
1967 22' Safari
AMARILLO , Texas
Thanks Lewster. BTW, another thanks for the tutorial AND excellent pictures (especially the pictures) you posted on the use of the Dometic drain cups. I couldn't figure out how I was going to mount those cups without turning the new unit over or at least sideways. All the "pros" said it couldn't be done. Looks like it'll be ok to turn it over for a short time just to get that finished. Again, many thanks!
Old 08-01-2016, 05:01 PM   #4
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
I painted the shroud on my safari rustoleum silver 6 years ago. Still looks better than when I bought the trailer with. Click image for larger version
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 08-01-2016, 05:53 PM   #5
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
My cover had started to crack around the edges so I strengthened the rim by adding aluminum HVAC tape on the inside and then applied a gel cyanoacrylate glue to the crack lines from the outside. I should add the cover was throughly cleaned with TSP first.
After carefully taping over the logo, I then painted my cover with Rust-Oleum's "Universal Silver" Automotive Paint for Plastic (#257389) from a spray can. Once dry, I removed the tape and totally sprayed it with Rust-Oleum's Automotive Enamel Clear Gloss (#257884), two coats.
It has been two years and it still looks great after every wash.
Sirs Gawain & Galahad
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 08-01-2016, 06:05 PM   #6
1967 22' Safari
AMARILLO , Texas
Thanks for the advice everyone! Sure hate to paint a brand new shroud, but looks like the way to go.
Old 08-02-2016, 11:06 AM   #7
1972 21' LY Globetrotter
manook's Avatar
1972 21' Globetrotter
Pico Rivera , California
Yes, painted my shroud after I put a good coat of primer on it. Looks a lot better than white.
manook is offline   Reply With Quote
Old 08-02-2016, 01:52 PM   #8
1967 22' Safari
AMARILLO , Texas
Thanks Manook,my thoughts exactly. Can I ask...Professional job, spray can, or brush? (Don't say brush, but I've seen it)
Old 08-02-2016, 02:41 PM   #9
Tampatomgirl
1990 34' Excella
Zephyrhills , Florida
I've seen it many times. Make it match your decor.
Tampatomgirl is offline   Reply With Quote
Old 08-02-2016, 05:35 PM   #10
1967 22' Safari
AMARILLO , Texas
Zephyr Hills! First time there last year. Enjoyed it! Hummmm, Decor? Silver of course! Thanks.
Old 08-02-2016, 08:45 PM   #11
911Patriot's Avatar
1991 29' Excella
Marco Island , Florida
Images: 42
Rivet Shrouded in Silver
Originally Posted by AldeanFan View Post
I painted the shroud on my safari rustoleum silver 6 years ago. Still looks better than when I bought the trailer with. Attachment 268118
That looks really nice!
911Patriot is offline   Reply With Quote
Old 08-03-2016, 09:34 AM   #12
Tampatomgirl
1990 34' Excella
I thought this post was referring to the inside cover. My bad.
Old 08-04-2016, 12:16 AM   #13
manook's Avatar
Spray cans for both primer and silver.
Has anyone painted this trim? TMT Cabinets, Counter Tops & Furnishings 4 09-09-2015 05:54 AM
Has Anyone Else Had a Bear Climb In Their Airstream? cclarkego Off Topic Forum 117 01-17-2011 08:30 PM
Has anyone put a photo tower on their Airstream? Msmoto Photography 4 12-13-2009 09:28 PM
Has anyone ever added on to their airstream wvairstream Full-Timing 18 11-16-2008 09:24 PM
Has anyone ever removed their air conditioning from engine compartment Mr. D Mechanics Corner - Engines, Transmission & More... 19 06-07-2007 07:11 PM
