Old 07-24-2014, 06:28 AM   #21
1978 31' Sovereign
1988 32' Excella
Linthicum , Maryland
Interesting thing - while waitiing for Clecos to arrive, nothin to (not quite true) I tried to use some Drywall Ankers (aka Toggle bolts) to pull the skin opening together. Voila- worked like a dream. I did put big washers on both sides to prevent pulling the screw straight the skin. Looks pretty nice even before I have rivets in place, which brings up next question: Olympic rivets or Buck rivets? And what tools are needed? Pro's and con's here, please.
RuneM46 is offline   Reply With Quote
Old 07-24-2014, 06:42 AM   #22
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
Galvanic corrosion
Originally Posted by RuneM46 View Post
Rib had a tear and slightly bent forward in it. I used 2 steel bars and was able to align the rib and got it straightened out.
In the picture you should be able to see the steelbar with 4 screws in it.Attachment 216582
If you leave the steel bars against the aluminum structure, corrosion will set in as soon as a little moisture condenses in between the two different metals. Basically, it's the same chemistry that is used in a battery, only slower.
Better to use aluminum to reinforce the rib and stop the reaction before it starts. Otherwise, use plenty of corrosion-resisting paint between the aluminum and the steel.
Old 07-24-2014, 06:48 AM   #23
1978 31' Sovereign
1988 32' Excella
Thanks MimiAndrews - will keep that in mind
Center front panel damage - Geico GettinAway Insurance & Claims 18 05-27-2011 05:05 AM
2005 Airstream Safari 22' (side damage) eBay Watch Airstreams on eBay 0 03-06-2011 05:40 PM
2005 Airstream Safari 22' (side damage) eBay Watch Airstreams on eBay 0 02-25-2011 10:40 PM
Curb Side & Front Glass Window & Clips Oceancontainer 1960 - 1965 Safari 2 07-28-2003 07:04 PM
