Old 10-15-2008, 09:15 AM   #15
On Rob's suggestions, for flagpoles I am using those extendable painters' poles that you can find at Lowes. They're made for screwing on a paint roller to reach high places without a ladder.
They are aluminum, and once you cut the handle off, they fit perfectly into the one-inch holes that most flagpole holders use. They're also fairly inexpensive, you can get one that goes from 6' - 12' for under $20.
Old 10-15-2008, 09:17 AM   #16
1998 28' Excella
Dolores , Colorado
We have one of the 3 pole holders on our unit and it works fine. I think that if a good wind came up with 7 flags on it you would probably air lift a few feet off the ground. We purchased our poles from Lowes. They are swimming pool cleaning poles that telescope in and fit in the pole holder quite well. We like the 3 flag holder because we can have a U.S., State, and Unit or military flag and that is adequate.
Member Four Corners Unit
WBCCI # 10105
Air # 28748
dogpound is offline   Reply With Quote
Old 10-15-2008, 11:11 AM   #17
Certifiable
mistral blue's Avatar
Proud Peacock
Stars and Stripes, Rob's 5er and pole-eze poles.
"IT'S A MAGICAL WORLD, HOBBES, OL' BUDDY... LET'S GO EXPLORING!" ~ CALVIN
mistral blue is offline   Reply With Quote
Old 10-15-2008, 12:02 PM   #18
Mexray's Avatar
1978 28' Ambassador
Morada , California
We have one of Rob's '3-holers' and use the roller paint extension handles from Lowes...the poles are the 'ribbed' type, and I had to slightly enlarge the holes in the holder with a small drum sander for them to fit properly...but it works great.
I think the poles were about $14 each...I cut off the handles which are plastic, using a hack saw lengthwise to carefully cut through the plastic. I drilled some holes in the poles and used stainless steel carbiners to snap into the flag gromments...
Name:	AS Mexray Blue Halo.jpg
Ray & Pat; Morada, CA
Old 10-15-2008, 12:19 PM   #19
99Limited34's Avatar
1999 34' Limited
Darien , Wisconsin
Originally Posted by hookedonclassic View Post
99Limited34: I just mounted Rob's 5 pole bracket to my 34. When I get home later today, I will post a picture for you. It turned out nice. I got 3 poles from Pole Ease to use with it for now.
Looking forward to seeing your pics... Thanks...
99Limited34 is offline   Reply With Quote
Old 10-16-2008, 07:35 AM   #20
hookedonclassic's Avatar
Fond du Lac , Wisconsin
Here are the pictures I promised.
Name:	IMG_0052 (Small).JPG
ID:	69470   Click image for larger version
Name:	IMG_0051 (Small).JPG
Rich
2010 43' Newmar Dutch Aire
formerly 2006 34' Classic
Changing the World One Child at a Time
www.compassion.com
hookedonclassic is offline   Reply With Quote
Old 10-16-2008, 09:11 AM   #21
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Show me how you attach your flags to your painter-poles.
pics:
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 10-16-2008, 11:59 AM   #22
Originally Posted by 65GT View Post
No need to cut those aluminum paint pole plastic handles off. Heat them with a hair dryer and they twist right off...
__
Yup, I did it over the stovetop flame, and then made a slit with an exacto knife, and they slid right off.
Old 10-16-2008, 12:59 PM   #23
Baltimore , Maryland
I drilled holes through the pole and use zip ties to put them on. A few poles have these West Marine: Spring Release Flag Clips Product Display which make it real easy to change flags. A bag of zip ties is easy too.
Old 10-16-2008, 04:42 PM   #24
Sonia's Avatar
2006 34' Classic S/O
1992 25' Airstream 250
anywhere , New Jersey
Originally Posted by 62overlander View Post
Rob has the best holder out there. They make the pole eze holders look like toys. Here you see a ton of flags all flying on Rob's holders.
Painter poles from Lowes work well too.
Thanks Frank for the painter poles info. We got the 5 flag holder from Rob and it is of great quality. We have the flags, now we just need to run to Lowes for the poles.
Sonia is offline   Reply With Quote
Old 10-16-2008, 04:53 PM   #25
in the broom isle.... 12' works best. See ya next weekend
Old 10-16-2008, 04:55 PM   #26
I started with the 4'-8' painters' poles and was disappointed with the (lack of) height. Definitely go with the 6'-12' ones.
Old 10-16-2008, 04:58 PM   #27
ctdair's Avatar
I too have a flag holder from Rob and rate it first class and worth the money. Used painter poles from Lowes 3 poles for less than $50.00
Name:	Metro Detroit 08 023.jpg
"Forbidden Wheels Clubhouse Recon Team"
S/OS #010
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2010 Dodge 2500 Diesel 4x4 Megacab
ctdair is offline   Reply With Quote
Old 10-16-2008, 05:55 PM   #28
Sounds like Rob gets glowing reviews....
Flagpole Holder kamadeca General Repair Forum 2 09-17-2008 08:23 AM
Flag holder barksdm General Motorhome Topics 7 07-14-2008 01:01 PM
Where to Buy 5 Flagpole Holder? craftsman General Repair Forum 36 02-15-2008 09:16 AM
Neat CB Holder Pahaska Our Community 12 11-19-2002 09:35 PM
Multi Flag Holder tenrsingr Our Community 6 06-10-2002 11:56 AM
