Old 03-30-2009, 05:15 PM   #1
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Flag Pole Holder Installation
I had ordered a pair of flag pole holders and poles for our Airstreams and had to get a little creative in attaching the holders to the jack stand tubes. Both coaches have the large motorized head and just attaching the holder directly to the pole would cause the jack head to interfere with the center flag pole. So I went to the local hardware store and rummaged through the miscellaneous nuts and bolts until I came up with something to use as a stand-off from the jack stand tube. I do not know what they are called, but they are 9/16" hexagonal and threaded all the way through. I added some flat and lock washers, bolts, and 2 1/4" muffler clamps. I primed and painted the guillotine part of the clamp black to match the jack stand tube. Then I added two coats of clear Plasti Dip to the "U" bolts. This afternoon I finally got to install one on our '87. Tmorrow I will install the other one on the '06
ID:	77662   Click image for larger version
ID:	77664   Click image for larger version
ID:	77666   Click image for larger version
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 03-30-2009, 06:00 PM   #2
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Nice install Carl!
ArtStream is offline   Reply With Quote
Old 04-05-2009, 12:35 PM   #3
DEITZ645's Avatar
The rain and wind finally stopped here so I was able to get to our '06 and get the flag pole holder installed. Here are a few pictures of the finished install.
ID:	77974   Click image for larger version
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 04-05-2009, 01:36 PM   #4
B4WEDI's Avatar
2006 19' Safari SE
Nawthin' , Hemisphere
Pretty Clean !
I think the trade would refer to them as " Coupling Nuts " Good idea !
Is that the flag holder from "Pole-Ease" ?
Are those the $15 generic painter's poles I have been reading about ?
*** KEEP LOOKING UP ***
T & K
B4WEDI is offline   Reply With Quote
Old 04-05-2009, 02:19 PM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
sweet! you know, you could take it a step further, and flip the flag pole holder around. then you'd have a flat surface facing forward, to which you could mount an outdoor electrical box...to which you can mount a 12v landscape light fixture to point up, and "alluminate" the flags at night.
(power it from the jack's power lead).
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 04-06-2009, 04:49 AM   #6
DEITZ645's Avatar
B4WEDI,
Thanks for the technical term. Yes the holder and poles came from Pole-Ease.
Chuck,
I did see a thread here where a light was mounted on the holder to shine up on the flags and it looked pretty cool and fairly easy.
If I were to turn the holders around to get that flat surface I would need to add another set of the coupling nuts as the jack head would interfere withthe poles again. I'll see what I can come up with and post it when I get it done.
Here's the link to the other post that shows the addition of a light.
http://www.airforums.com/forums/f286...ket-19116.html
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 07-27-2010, 08:35 AM   #7
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
I purchased one of Rob's holders. I installed it using Carl's (Deitz 645) method and I worked great. Easy install and it seems to be nice and secure.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Flag pole holder grnthumbguy Exterior Restoration Forum 3 10-21-2017 11:23 AM
Installing pole ease flag holder on new AS yakman General Repair Forum 30 11-02-2014 10:12 PM
I Want a 5 Pole Flag Holder/Bracket myboyburt WBCCI Forum 45 12-28-2008 06:45 PM
pole-ease flag holder question Chuck General Repair Forum 9 10-07-2008 12:20 AM
Flag pole bracket/holder? Kistler Our Community 7 11-25-2003 10:29 AM
