Old 11-28-2014, 12:22 PM   #1
Exterior teardrop running light replacement
Does anyone know what kind of gasket or sealant to use when replacing the teardrop exterior running lights? Also best method for removing the old lights?
broox is offline   Reply With Quote
Old 11-28-2014, 12:37 PM   #2
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Not sure about the gasket, but I just used Silkaflex 221 Gray on mine, which is sold on Airstream's online store.
There is a screw in the top of the light, that holds the cover on, then on the inside the screws that attach it to the body.
You can also use, Parbond Gray or Clear (small hand tubes) or
Loctite® PL® S40 Polyurethane Window Door and Siding Sealant as some others have reported doing.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 11-28-2014, 03:18 PM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
You can make your own gasket by purchasing some sheet stock from a hardware store and cutting it to fit your fixture. I'd recommend the gasket rather than sealant to make it easier to remove in the future to replace the light bulb.
Bob Martel
WBCCI# 5766
Exterior teardrop light cover removal 2011 FC geeman Electrical - Systems, Generators, Batteries & Solar 1 05-17-2014 09:02 PM
Custom handmade teardrop teardrop trailer: Airstream lovers behold! eBay Watch Airstreams on eBay 0 12-21-2013 05:30 AM
New LED teardrop Clearance Light Removal dkottum Lights - Interior & Exterior 2 03-28-2012 09:27 PM
Teardrop Marker Light toastie Lights - Interior & Exterior 5 02-23-2008 09:02 AM
LED Running/marker Lights-Teardrop BornToRock Electrical - Systems, Generators, Batteries & Solar 2 12-18-2006 12:46 PM
