Old 04-23-2013, 08:48 AM   #1
1965 26' Overlander
Ogunquit , Maine
Exterior Refrigerator Vent Cover
Does anyone know of a source to purchase a replacement refrigerator vent cover for a 1965 A/S Overlander? I tried VTS and they are out of stock and an availability date uncertain at this time. My cover was in shreds and now totally missing. I did cover the opening with foil tape to keep the rain out. I am assuming I will be unable to use the unit on electric with the vent blocked. Thanks, Dom
dominicjohn is offline   Reply With Quote
Old 04-23-2013, 09:07 AM   #2
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question Check Inland RV...
Does it look like this?
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 04-23-2013, 11:05 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You can use it while in the electric mode, but not on gas. It may not be as efficient because the heat needs to escape somewhere.
Old 05-13-2013, 07:59 AM   #4
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
I would like to know the answer to this also. The one Bob linked to will work, but I would like to use the original smaller sized one that uses the same rivet holes. Mine is a Caravel. I have no idea if VTS will get another shipment of the 24" ones. If anybody knows if they will, or if there is another source let us know. I can wait as there is a home made version up there now, but it is more functional than pretty.
1965 Airstream Caravel, 2003 Ford F150 SuperCrew, 2003 Miata Special Edition, 1993 Miata Black & Tan
Jewel65 is offline   Reply With Quote
Old 05-13-2013, 09:58 AM   #5
Airstream parts stocking dealers will have the metal replacement reefer vent cover.
For those that want the smaller one, there is an easy answer of how to make the longer one work.
First of all, plastic is plastic and plastic replacements will fail again and again.
And, the metal one is even cheaper.
All someone needs to do with the longer cover, is to cut it in half, overlap it to whatever dimension they want, and rivet it back together, with a small bead of sealer on the seam.
Old 05-14-2013, 12:01 PM   #6
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
That's not a bad idea Andy. I might just do that. Thanks for the reply!
