Old 12-02-2004, 11:46 AM   #1
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
Question Exterior electrical outlet cover
I had the exterior cover come off in my hand when opening up the electrical outlet! This is held in place by a pin extending outward into the box riveted to the side of the trailer. The pin acts as a hinge. The pin is broken off. do I remove the whole box replace pin and re rivet to side of trailer? The outlet looks to be between the interior and exterior wheel well covers. I am redoing interior and have easy access to wheel covers. Don't want to redo rivets unless it's only way! Anyone been here?
Paul
Troy MI
1978 Tradewind
1978 Sovereign
airstream4 is offline   Reply With Quote
Old 12-05-2004, 01:37 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Paul,
Sorry to be the bearer of bad news, but the box has to be removed to fix it. You may do better getting one from a boneyard. The hinge pin is pressed into the fixture prior to installation in the coach. I had to replace one for the same reason and now I keep it well lubed.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
vent cover repair.... Chuck Windows & Screens 10 11-13-2002 12:05 PM
cover for univolt maznblu Electrical - Systems, Generators, Batteries & Solar 2 09-15-2002 07:02 PM
Help!! exterior outlet cover stuck TheBigRedTruck Electrical - Systems, Generators, Batteries & Solar 8 06-28-2002 11:04 AM
Trailer Life cover 83Excella Our Community 6 06-16-2002 10:14 AM
Exterior 120 volt outlet cover thenewkid64 Electrical - Systems, Generators, Batteries & Solar 8 06-16-2002 08:54 AM
