Old 10-17-2004, 04:40 PM   #1
expanding foam insulation
Has anyone used expanding foam insulation to replace the factory insulation? I've removed the aluminum and insulation under my Caravel. I found a host of problems, from wiring that had been chewed through to a poorly constructed frame. I've fixed everything but I'm thinking expanding foam would be an excellent deterrent to keep rodants out. I was also thinking it could firm up the walls making the entire trailer less prone to dents, etc.
I had heard this type of foam could crubble, but I've not been able to find any confirmation to that.
Dave
DinubaDave is offline   Reply With Quote
Old 10-17-2004, 05:25 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by DinubaDave
Has anyone used expanding foam insulation to replace the factory insulation? I had heard this type of foam could crubble, but I've not been able to find any confirmation to that.Thanks,Dave
Welcome to the Forums!
Yes, it has been tried, yes it crumbles. Because the inside and outside of the coach move slightly against each other, it would turn to powder in short order. The good old-fashioned fiberglas insulation still is the preferred method for insulating our trailers.
Old 10-17-2004, 05:48 PM   #3
Thanks Terry. Dave
Old 06-30-2005, 12:13 AM   #4
desi arnaz's Avatar
where do you get 2 inch thick pink?
desi arnaz is offline   Reply With Quote
Old 06-30-2005, 12:19 AM   #5
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Home Depot, Peel the paper backer off and you will end up with approximately 2" thick insulation.
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 06-30-2005, 02:41 AM   #6
desi arnaz's Avatar
HUH>? is this a peel and stick insulation?
Old 06-30-2005, 03:28 AM   #7
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
No, the paper backer C Johnson mentioned is the kraft-paper vapor barrier which is not needed for this application.
No stickiness involved.
Tom
Old 06-30-2005, 05:16 AM   #8
Well Preserved
1993 21' Sovereign
Tom
And since our trailers "sweat," a vapor barrier would be detrimental. It would keep the moisture inside the walls, not a good thing.
Old 06-30-2005, 08:19 AM   #9
desi arnaz's Avatar
but isin't that a 3 inch insulation? is that too much compression?
Airstream Insulation Craftsman General Interior Topics 24 01-11-2016 07:45 PM
Insulation used in Classic Limited series - 2004? flyfisher 2001 - 2005 Classic 20 11-08-2004 03:38 PM
foam under plywood flooring? JeepinAudiophile Repairing/Replacing Floor &/or Frame 3 07-12-2004 08:44 PM
Under floor insulation Rick Alston Repairing/Replacing Floor &/or Frame 18 01-26-2004 08:02 PM
Glass windows; insulation smallfry Windows & Screens 5 01-10-2003 05:15 PM
