Old 08-06-2015, 04:02 PM   #15
Originally Posted by bigfoot390 View Post
Andy,
Are you saying that the stripe is on a sheet of metal that can be removed? What is underneath? Could I replace it with another ribbon of aluminum? That might look better then all the work of removing the blue and restriping it. A roll of aluminum also is alot cheaper then new vinyl strips.
Bill
Bill.
As I recall that blue stripe was a piece of vinyl covered aluminum.
Old 08-06-2015, 04:07 PM   #16
Originally Posted by Not Done View Post
Andy,
Thank you as always!!!
I should be able to take the panels to an auto paint shop. They won't take the trailer but the panels shouldn't be a problem.
Thank you,
John
John.
I suppose that could be done, but I would insist on "flexible paint", since I am sure that it would be flat when painted, and then coiled up so you could transport it back to the shop, and then unwound again.
Old 08-07-2015, 10:08 AM   #17
1973 31' Excella 500
Marysville , Washington
Thank you Andy.
Not Done is offline   Reply With Quote
30 minutes to remove the big blue vinyl band nickcrowhurst Clearcoat, Exterior Paint & Trim 17 01-22-2017 01:32 PM
Newbie and waist deep in restoration. toddhowell Member Introductions 0 08-21-2012 07:18 AM
What's under the wide blue band? JimGolden Clearcoat, Exterior Paint & Trim 20 06-07-2009 07:27 PM
