Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum
Old 04-30-2006, 10:54 AM   #1
AnnabeltheCaravel
chalcedon's Avatar
Profile:  1967 17' Caravel
drip caps
Hello.
Does anyone know the diameter of pre drilled mounting holes is aluminum after market drip caps?
Also; what size would i need to fit 17 inch windows?
Not too sure how the drip caps are measured.
Thanks.
Eric..
chalcedon is offline   Reply With Quote
Old 04-30-2006, 11:17 AM   #2
Profile:  , Minnesota
Images: 59
Airstream Registry
If you are asking about the drip caps made by Grace Manufacturing, the overall length is the window length + 3 1/2", and you order by window length. They are available in increments of 2 to 3".
So if you have a 17" window, you would order a 18" drip cap, and the overall length would be 21 1/2".
Airstream Wheels JAG Wheels 10 06-01-2006 08:54 PM
Dull walls and yellow plastic ends 74SovereignInt. Upholstery, Blinds, Walls & Interior Finishes 35 10-15-2004 12:57 AM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 01:35 PM
Water Drip uwe Fresh Water Systems 6 07-11-2002 08:39 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
