Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum
Old 10-20-2008, 09:13 PM   #1
damonbeals's Avatar
Profile:  1998 31' Excella 1000
Mooresville , Indiana
Door screws stripped, any suggestion on how to fix it.
Looks like the previous owners of our 99 31' Excella had trouble with the door and not only stripped the heads of the screws but stripped the nut in the frame as well. Does anyone have any suggestions how to fix this? The door is semi secure but you can turn the screws and they get tight but then the hinge has alot of play in it. The little pins that go in the hinge and frame are also broken off, I assume they should be replaced with something.
Looking for any suggestions!
Damon
damonbeals is online now   Reply With Quote
Old 10-20-2008, 10:33 PM   #2
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Try monofilament fishing line inserted into the “nuts” and then starting the screws. It comes in different thicknesses (weights) up to weedeater line. It also serves as a self-locking nut. Not as satisfactory solution as replacement, but quick, cheap, and easy. Multiple lines can be inserted too.
Could at least hold off a difficult repair.
Vaughan
A sixth sense (I lack the other five) tells me that I am in serious difficulties. Oscar Levant
vswingfield is online now   Reply With Quote
Old 10-20-2008, 11:31 PM   #3
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
If and when you need to replace the hinges, you can use a Dremel tool with a cutoff wheel to cut a new slot in the screw so you can use a flathead screwdriver on it one last time. This will likely damage the hinge, so plan on replacing it at that time. The screws in the body are probably just sitting in there, so be aware that when you do unscrew the screws, you should have a pair of needlenose vice grips, or something comparable, to hold the nuts, or they will fall into the body, and be gone forever.
(No Longer at Inland RV)
Old 05-04-2009, 12:58 PM   #4
Profile:  1983 31' Excella
Wellfleet , Massachusetts
I have a tool that you drill a hole a little oversize in the exisiting hole ,then you insert a "nutsert" which is threaded on the end of a tool similar to a pop rivit tool . After squeezing it tight it leaves a threaded nut in the original opening .
Don
Don.44 is offline   Reply With Quote
Old 05-04-2009, 01:04 PM   #5
Mike Leary's Avatar
Profile:  On the move , Las Cruces, NM
Try all the above suggestions; it's a huge pain to get at that area. I know.
1983 310 Turbo Diesel Mo/Ho "Bess" 212,292 miles
Full timing since 1994
Mike Leary is online now   Reply With Quote
Entrance Door Lock Fix Inland RV Center, In Doors & Locks 76 08-16-2008 06:24 PM
Easy fix for Door Problems jking Classic Motorhomes 1 07-01-2006 02:16 PM
Entrance Door Fix Chaplain Kent Doors & Locks 0 06-30-2005 08:23 AM
Stripped-out airstream wanted Andrej For Sale & Wanted 31 04-08-2004 01:18 PM
can a 92 limited classic be stripped and polished? 0557 Cleaning, Stripping & Polishing 6 02-23-2004 10:14 AM
