Old 01-26-2006, 03:57 PM   #1
1972 25' Tradewind
Oakhurst , Texas
Dissimilar Metal Corrosion
In the process of repairing the rotten floor and corroded metal at the rear of my 25 Trade wind I found a 42 inch long strip of steel riveted to the inside of the rear skin at the floor, were it has caused considerable corrosion. It is placed so as to fit under the wood floor panel.
Any idea why Airstream would have installed the steel, it is about 14 gage thick, and what would be wrong with replacing it with 2024 of the same thickness.
Your comments will be appreciated
JIM Bowers is offline   Reply With Quote
Old 01-26-2006, 04:15 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Replacement of steel with aluminum
It depends on what the steel was in there to accomplish. If it was a stiffener to prevent bending or spreading out a stress then you would want to use an aluminum piece that would have the same resistance to bending. Aluminum has a mending modulus one third that of steel. Therefore you would have to use a thicker piece of aluminum. Since stiffness goes by the cube of thickness, you would have to use a piece of aluminum that was 1.4 time the thickness of the steel piece to get equal function. Make sure you do not use steel bolts to attach it or you will have the same corrosion problem from the bolts. I use plastic washers under stainless steel fasteners when I do something like this.
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 06:30 PM
Favorite Jerry-Rig? Dave Cole General Repair Forum 58 10-07-2013 09:50 AM
Dissimilar metal corrosion Safari Tim Ribs, Skins & Rivets 21 05-17-2005 02:22 PM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
Hitch inspections 83Excella Hitches, Couplers & Balls 3 07-09-2002 03:05 PM
