Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum
Old 11-11-2008, 08:01 AM   #1
Profile:  1970 25' Tradewind
Glen Burnie , Maryland
Dent Questions
My '70 TW has lots o' dents. Most are small in the forward lower areas, mostly from highway debris, they look like they could be easily dollied out. But there are a few large up top in the rear and a pretty severe crease on the right from amidships forward through the entry door and fridge access (see my gallery). I really don't want to touch the interior, it's all original and in VGC.
Has anyone had any luck with suction cup dent pullers?
Any way to fix that crease without pulling cabinetry and interior skin?
Zoomie is offline   Reply With Quote
Old 11-11-2008, 08:56 AM   #2
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
I just looked at your pictures and the only way to fix those panels along the right side is to replace the panels. I have replaced all of those panels on this thread
http://www.airforums.com/forums/f381...nte-26902.html
Kip
Old 11-11-2008, 09:32 AM   #3
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
That is crease is such a close call narrowly escaped I'd *almost* be happy to leave it.. The back corner can be rolled out somewhat but it will show something happened there..
Aluminum is so soft there is no returning to a flat surface - once it has stretched there will always be a concave or convex quotient plus tool marks appearance wise. One can return a dent to a approximate prior appearance but if there is adjoining perfect plane panels it will stand out brightly.
The crease is there for good unless you swap out the 2024 aluminum sheet - however you can use heat and cold to contract some of the stretch so the furrows width and depth so overall from afar it isn't so noticeable... I used dry ice and a heat gun, but know dry ice reacts with the aluminum surface something akin to sanding it with 400grit sandpaper.
Powered by Tinnitus
Parkside Logic - My Site & Blog
Old 11-11-2008, 09:42 AM   #4
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
I tried cheapo suction cups from Harbor Freight. Not much luck. Ding King or Pops a Dent worked better. You can also use the butt end of 2x2 lumber scraps with a hot glue gun to pull out dents. I've pulled out my front end dents quite a bit this way, but the only way I see to completely get rid of them is to take off the inside skin or replace the panel. I plan to put on some stainless rock guards to cover them up.
Pay no attention to the man behind the curtain- WoZ
Old 11-11-2008, 10:05 AM   #5
Diesel1's Avatar
Profile:  1967 24' Tradewind
Kingman , Arizona
Thanks for the hot glue and 2x2 tip. I shall try that. This place is a font of knowledge! Adios, John
Diesel1 is offline   Reply With Quote
Old 11-11-2008, 08:22 PM   #6
Thanks for the advice. To be honest, I got the TW in trade for a house painting. Until I saw all the beautifully restored Airstreams here I was going to leave it and use it, since the few dings and dents, and the non-operable refirgerator and AC unit were the only things wrong with it.
But as these little things add up, and considering that I already have not one but TWO floating moneypits, I think I'll just replace the fridge, clean the old furnace and water heater, pull what dents I can, give her a good polishing this Spring and leave it at that. Not discouraged, just being realistic.
Thanks again.
Old 11-11-2008, 08:40 PM   #7
Airslide's Avatar
Profile:  2001 30' Limited
Novato , California
Images: 47
Send a message via Yahoo to Airslide
Great plan.. enjoy your airstream!
2001 Airstream 30' S/O 70th Anniversary
1994 F-350 Crew 7.3 IDI Turbo, C6, Dually
Airslide is offline   Reply With Quote
Big Dent Silver Threads Ribs, Skins & Rivets 11 06-27-2007 09:16 PM
Dent flyguy Ribs, Skins & Rivets 19 06-08-2007 01:46 PM
First Dent - HELP! JimGolden Ribs, Skins & Rivets 10 01-08-2007 01:47 PM
Removing a dent dmadam Ribs, Skins & Rivets 7 04-03-2004 01:03 PM
dent down low John Greenlee Ribs, Skins & Rivets 5 03-27-2004 08:29 AM
