Old 05-28-2015, 08:28 AM   #1
1970 27' Overlander
Warwick , Rhode Island
Dent question
I'm looking into buying this airstream. should I be concerned about the dent on the rear corner? Is this a big deal to fix? Thanks
erikusl181 is offline   Reply With Quote
Old 05-28-2015, 08:33 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Picture would help.
MICHAEL
Old 05-28-2015, 09:04 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If the dent is a crease from running into something, sometimes it can be pulled out with a suction cup and persuaded by malot on the edge of the crease. It there is stretching of the aluminum, it is not repairable. Replace the panel.
Old 05-28-2015, 10:09 AM   #4
1970 27' Overlander
Sorry. I thought I added the pic.
Old 05-28-2015, 10:13 AM   #5
1970 27' Overlander
Pic
Old 05-28-2015, 10:30 AM   #6
1974 Argosy 20
Kooskia , Idaho
I doubt that the dent you show can be repaired. You will have to have the panel replaced which is a pretty expensive job. The upper panel also looks to be damaged and might also have to be replaced. Only an AS expert can tell you that.
You also can just live with the "beauty marks".
Dent Removal uwe Ribs, Skins & Rivets 11 01-17-2016 01:48 PM
Another Roof Dent Question airtime Roof 6 09-15-2010 06:09 PM
Dent Pullers wagsrp Ribs, Skins & Rivets 12 07-30-2009 07:14 AM
The dent, another question... Kistler Our Community 1 08-24-2003 12:40 PM
Dent Repair Jim W Ribs, Skins & Rivets 3 05-07-2002 11:43 AM
