The Rib-
See if you can straighten the rib out a little by working it with a 2.5lb hammer, a 1/2in punch, a large C-clamp, and some vice grips. If you are not happy with the result, remove the rivets attaching the the skin to the damaged part of the rib then cut out the damaged part of the rib and take that piece to a sheet metal shop. Take pictures with you, explain what you are trying to accomplish, and have them make a similar piece that is slightly larger or smaller in width and about 2 inches longer so you can sister it in to the original rib with rivets.
The Skins-
Not much you can do about the dimples. Replacement panels cost about 4-600 dollars each depending on panel size with ridiculous shipping charges. Out of Doors Mart probably has the panels you need.
http://odmrv.com/catalog/index.php?m...ex&cPath=98_99
