Old 07-18-2009, 11:41 AM   #15
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Originally Posted by sr5bidder View Post
yeah Stefrobrts I will consider all input thats why I'm asking. I do not have the moneys for a full resto.
I have not seen this in person either and was wondering if its even movable with the floor out? 50-60 miles
Moving it depends on how the floor was removed. the floor is sandwiched between the frame and the shell. As long as it is still connected it should stay together, but the overall trailer won't have the rigidity it would have with the floor intact. The frame is actually quite weak. It needs all three parts - frame, floor, shell - for strength. If it were my project I would have it moved on a flatbed, but that's just me.
Stephanie
Old 07-18-2009, 11:44 AM   #16
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Only love, not hate
I've had similar dreams for a cool open porch on the back. I would've used a classic MH. Don't know if the TT frame could support the cycles weight rolling down the road. I almost bought a funeral coach a few montha ago. Thought the flip down stairs for the flower area would make a great entrance.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 07-18-2009, 11:51 AM   #17
Baltimore , Maryland
i'll buy any windows, hatched or doors you cut out of that thing. The axles are not the only thing not able to carry the weight. The frame is also under rated for what you want to do.
Old 07-18-2009, 02:26 PM   #18
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I like the idea but you have a serious problem !!!!!!!
1. First the axle is probably shot and new one is $800 and you would need a 5000 lb one probably, more money.
2. The frame is no where strong enough to support that kind of weight.. The shell helps hold up the frame. Thus you would have to reinforce it past the axles, which would add more weight... Have you seen an AS frame. they aren't made of much...
3. With that much weight behind the single axle it would tend to sway and swing.
I think you would be putting more money into it than you would want too. You need an 80's trailer. Most 60-70's trailers need new axles and that is nearly $2000 for a double axle...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-18-2009, 02:40 PM   #19
Obsessed with Moonunit
COArgosy78's Avatar
1978 Argosy Minuet 6.7 Metre
Love It Here , Colorado
Images: 55
First off, I probably have no idea what I am saying structurally/or how you would do it...but here goes. If you found a double axle trailer in the 80's range and could do double doors on the side (opening opposite of each other), toward the front where the load can take it better, would that opening be wide enough for bikes up a ramp? Then, remodel the rear for living? Weight distribution is a very big thing in trailers - I found out the hard way
Leigh (IB Aluminated)
"When a great ship is in harbour and moored, it is safe, there can be no doubt. But that is not what great ships are built for." by Clarissa Pinkola-Estes, author of ‘Women Who Run With the Wolves’
COArgosy78 is offline   Reply With Quote
Old 07-18-2009, 02:44 PM   #20
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
If ya want a toy hauler GO cut up an ole SOB U can probably fine one that will do the job for 4 or 5 hundred. It would be a travesty to cut up that FC. What everyone has told ya is the truth. When ya start messing wiff the shell it weakens every other thing. Seeing its a MONO COUPE design and each part rely s on everyother part to make the overall strength. Find an SOB that has a channel or I beam frame and a tandem to carry the weight. But no matter what we say here you will do what U want ITS YOUR $800 bucks. But my thought it would be a sin to cut up that particular trailer. Just my thoughts
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 07-18-2009, 02:48 PM   #21
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
It sounds like that particular trailer may already be sold anyway. That's another problem with Airstreams, when you decide you want one, you really have to jump on it! I spent about 6 months looking for mine, getting beat out every time I found one, until I finally placed a wanted ad in teh local paper. This time of year especially they are hard to score
Stephanie
Old 07-18-2009, 04:09 PM   #22
COArgosy78's Avatar
Images: 55
Here's another possibility, especially if you are a do-it-yourselfer. Keep looking for an AS, but make it a motorhome (yea, they cost a bit more, but if you watch-who knows!). Then you have the AS for living & can tow the bikes in something else.... maybe much less costly in the long run
Old 07-18-2009, 04:58 PM   #23
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
You would have to build a ridged frame and set your shell on it. Check out older Avions, they were a little stiffer. Silver Streak was ever stiffer yet, some with a 3 rail frame. There's a guy up here with your idea. He has an old 30 ft Spartinett, aluminum but flatside. He's cutting 5 ft out of the middle, bringing the ends togather. He's putting a door in both sides on the back, and using ramps. Drive his bike in one side & out the other! Front 2/3s for living. Gonna try to use his appliances way to the front for ballance. Bet you could tripple your money on that cloud!
putback is offline   Reply With Quote
Old 07-18-2009, 06:12 PM   #24
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
It would be a crying shame to cut that baby up. The frame and single axle aren't strong enough anyway. You'd be better off finding a SOB or wrecked, newer Airstream.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-18-2009, 10:49 PM   #25
marietta , Georgia
Well y'all I thank you for your input seems someone beat me to that one thankfully!!
I found a double axle 1971 and have decided I can carry bikes in the tow vehical.
I looked at the brand new AS today at camping world ...man they are slick!!
I will look at the 71 tommorrow, its complete with soft bathroom area and everything is intact not saying where I found it ...seems some of you can't have enough A.S.
I'm sure it will need some work, camping areas are not the cleanest enviroment, so I'm thinking of aluminium diamond plating the floor... is there any body who has done this?
what is a SOB?
sr5bidder is offline   Reply With Quote
Old 07-18-2009, 11:03 PM   #26
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
My father-in-law (Bob) says SOB stands for Sweet Old Bob. But we also call non-airstreams, Some Other Box, or a variation there of.
newroswell is offline   Reply With Quote
Old 07-18-2009, 11:58 PM   #27
marietta , Georgia
some old box hmmm thanks I;ll rememner that one
where do the water supply lines run in the 71 models? it appears I will need to run al new lines
tomorrow will be interesting I'll take pics and confer with y'all
Old 07-19-2009, 08:17 AM   #28
1977 27' Overlander
Trotwood , Ohio
sr5bidder
ITs SOME OTHER BRAND also. If ya diamond plate the floor you will run into a weight problem. Why do u have to modify a perfectly good thing.? But it appears you have mods on your mind and will not be swayed. Its your investment that you are destroying.If you go to those extremes it will not be usable to anyone else in the future and will end up in the salvage yard.
Roger & MaryLou
___________________
KA8LMQ
Does anyone else hate camp fires? Wayne&Sam On The Road... 573 05-02-2014 07:43 PM
RM 3807 Refridge-I-hate-ya dalefox Refrigerators 3 08-05-2008 01:13 AM
I hate hail! B25guy Ribs, Skins & Rivets 64 07-10-2008 03:06 PM
I *HATE* hail! Westfalia On The Road... 6 06-28-2008 09:47 PM
aaaaaaRRRRGGGGG! I hate UPS RichardT General Motorhome Topics 36 11-10-2005 03:52 PM
