Old 10-20-2015, 07:53 AM   #1
1963 30' Sovereign
brandon , Mississippi
Cleaning or Polishing
I have a 63 Sovereign. I want to even out the color but really polish it super bright. I like the grey, brushed aluminum look.
I have to remove a lot of coal tar from the roof, someone thought this was the best thing since sliced bread.
Any suggestions?
poolman03 is offline   Reply With Quote
Old 10-20-2015, 08:51 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Super bright/ Grey brushed? Sound like you are talking about opposites. Please clarify.
Coal Tar? Try different solvents and a heat gun.
Old 10-20-2015, 02:42 PM   #3
1963 30' Sovereign
Yea, I didn't type that up correct at all. I don't want the blinding super brite shiny look. I want a even grey clean look.
Old 10-20-2015, 03:20 PM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
First thing is to figure if you have any clear coat left on the exterior. Probably not much but unless you remove it you will have a splotchy finish. Strip off the rest of the clear coat with a paint stripper. Use a plastic putty knife. you might like the look without doing anything else.
Then you have some options: use a auto wax, use auto compound, or use a coarse grade of Nuvite, or tripoli. You will need to consider if you want to invest in a adjustable speed grinder and or a Cyclo polisher. The Cyclo is the best way to avoid the dreaded "swirls". for what you want to do you may be able to get away with a hand drill with a polishing attachment. A 30 footer is a lot of work. Experiment.
Old 10-20-2015, 10:42 PM   #5
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I got my '61 Safari (no clearcoat for this year) to a nice, clean, even grey by several rubdowns over a few years with Bon-Ami "Hasn't scratched yet" cleanser. I use about one 14 ounce container per cleaning for my 22' trailer and spend about an hour and a half with the rubdown. Try it. If you don't like the results you are out only a couple bucks and some elbow grease. It will remove black marks, mold, and rust stains without polishing.
Sam
samb is offline   Reply With Quote
Old 11-03-2015, 08:38 AM   #6
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
For the tap and sap residues any citrus glue /adhesive removed will do. I am a big fan of rapid remover. It's what I use at work. I used it to get the sap of the roof, the tar from the belly front and it cleans off old vulkem sealant and buytl tape so easily if you have to redo any weather-stripping as well as any dried on crud from old duct or masking tape.
Spray it on with an old windex bottle or whatever youve got and leave it sit 30 to 60 seconds and wipe or scrape off depending on how thick it is. Repeat as needed. It also works on the interiors with the vinyl walls that get super sticky spray on, rub in with a soft nail brush and paper towel it off, repeat. I used a whole gallon on the restoration of my 69
thesignlady is offline   Reply With Quote
Old 01-25-2016, 10:28 PM   #7
1981 28' Airstream 280
Sevierville , Tennessee
Where do I get a cyclo polisher? What kind of stripper do you use to remove spotches of clearcoat? Do I have to reapply clearcoat after polishing? If so, how? .....thanks
bjeanetted is offline   Reply With Quote
Suggestions for cleaning/polishing options with little time? Boondocker Cleaning, Stripping & Polishing 12 01-25-2016 10:32 PM
cleaning and polishing gsgofish Cleaning, Stripping & Polishing 3 05-11-2010 08:19 AM
Cleaning vulkem after polishing ronstory Cleaning, Stripping & Polishing 1 10-26-2008 12:01 PM
Cleaning Wool Polishing Cloths dbaur Cleaning, Stripping & Polishing 13 12-23-2007 01:18 PM
Cleaning and Polishing plastic windows? Resorts Rock Guards, Segment & Window Protectors 2 06-11-2007 07:31 AM
