Old 10-28-2015, 03:25 PM   #1
1969 23' Safari
Athens , Georgia
Citristrip
I decided to take the plunge and strip and polish my Safari. After doing online research, I decided that Citristrip was wanted I wanted to use. One video that I saw said to apply in 18" sections. So...I painted it on, waited about 30 minutes and washed it off. The clear coat came (mostly) off that section with a garden spray hose! Yay! So, on to the adjoining section. It was wet from the prior rinse and did NOT come off. I had read somewhere that that would happen. What is the harm in doing larger sections, say, half a side one time, half the other side? It's been raining ever since, so I'm at it again tomorrow. Thoughts? The Citristrip bottle says to leave on from 30 minutes to 24 hours. Why work in smaller sections?
sarasafari is offline   Reply With Quote
Old 10-28-2015, 03:46 PM   #2
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
You can work in larger sections. Remember the directions are for furniture, cabinets or wall. What will leaving on a little longer do to aluminum-nothing. You may end having todo a little hand scrubbing with a wet sponge.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 10-28-2015, 05:44 PM   #3
Central , Mississippi
I've had good luck with citristrip BUT I use it slightly differently than the directions.
I slather it on with a paint brush, wait :15 or so then I scrub it with a soft bristle car wash brush. I add more fresh stripper and repeat as often as needed until the scrubbing turns into goo.
Then I wash it off.
So far it's worked on my '77, my '91 and my '63 with great results.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 10-29-2015, 07:25 AM   #4
1969 23' Safari
Athens , Georgia
Thanks!
Old 10-29-2015, 07:36 AM   #5
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
In my experience (removing paint from inner skins), the only danger in working in larger sections is leaving it on so long that it dries out. In this case you pretty much have to start over on the dry sections.
BambiTex is offline   Reply With Quote
Citristrip Cardinal283 General Repair Forum 2 02-16-2015 12:45 PM
Using Citristrip to take off clearcoat Jim in Pima Clearcoat, Exterior Paint & Trim 7 04-28-2014 09:19 PM
Remove water-spots from removALL/Citristrip DustDom Our Community 3 06-21-2012 07:14 PM
Any problem with using Citristrip? glacierrunne Cleaning, Stripping & Polishing 1 02-01-2010 05:14 PM
Tried citristrip and aircraft remover? evelitalian Cleaning, Stripping & Polishing 15 03-22-2008 06:23 PM
