Old 11-29-2005, 01:00 PM   #1
1966 22' Safari
alpharetta , Georgia
Can she be fixed?
I just picked up this 66 Safari. I have all of the pieces missing from the front and they are in good condition except for the bottom curved pieces. I know the door will be tough to find. I have $475 in it as it stands.
Pinhead is offline   Reply With Quote
Old 11-29-2005, 01:30 PM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
You've certainly got a challenge. Can it be fixed? With enough time and money, most anything can be fixed. The amount you have or are willing to spend of either will determine if you'll be able to fix it. If the window frames are missing, that will be another significant challenge, just like the door. May be best to part it out and look for another that is in a more complete condition but it's entirely your call. How are your mechanical skills?
Whatever you decide, best of luck to you.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 11-29-2005, 01:45 PM   #3
1966 22' Safari
Window Frames are all there, surprisingly the floors are solid. The axle sill has a negative slant. My mechanical skills are pretty good and I have air tools, welders, sandblaster etc. My 20 year old son has volunteered to help so I do have some cheap labor.
Jon
Old 11-29-2005, 02:03 PM   #4
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Hi Jon -
In studying your photos, it looks like the window frame on the front window, for example, is missing. Remember, there are two wondow frames; one riveted to the body and the other that fits inside the other that opens with a window crank or two. The side windows are the non-framed Corning ones and they are currently being reproduced through 'VintageTrailerSupply.com' They are the only supplier that will be able to provide these providing your opening match their current offerings.
Any more photos to post? How's the interior? Or maybe that isn't important to you if you plan on making your own.
FF
Old 11-29-2005, 02:03 PM   #5
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Hmmm that I've seen that trailer before - it was For Sale, guess that means you bought it.......
I would say if you have all the pieces, and skills you mentioned - could be a fun project....you should be able to reproduce the door with good sheet metal skills.....
It would be more than I would take on, but if your up to the task, we are here to walk you through the project......
Welcome to the forums....
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 11-29-2005, 02:27 PM   #6
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Pinhead, Bob's RV Salvage in High Springs, Florida, may be able to help you out with a door and other things. Don't have his number handy, but it is a 386 area code.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 11-29-2005, 03:15 PM   #7
1966 22' Safari
Yep this was an eBay special, but since it was local and I like to work an stuff I went for it. I see what you men about the front window frame; Iíll need to add that to the list. Here is a picture of the inside, itís not pretty but we will not be doing a resto on the inside just functional. Thanks for the encouragement this is a great forum, Iíve learned a lot in the past few days.
Jon
Old 11-29-2005, 05:43 PM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Always wondered what a full monty on the hoof looked like You definitely got you a fixer upper. But it is not an impossible project...
Aaron
WBCCI #XXXX AIR #2495
Old 11-29-2005, 06:13 PM   #9
aztlanco's Avatar
El Paso , Texas
Send a message via AIM to aztlanco
That is a project but a good starter. Seems you have most of the basics and if you are not going "RESTO" you can fabricate a great deal of what's missing. You are certainly going to enjoy and have fun doing this one and at the same time, quality time with your son. Good luck.
Ernie
'58 Traveler, 18ft.
aztlanco is offline   Reply With Quote
Old 11-29-2005, 08:40 PM   #10
moogie32's Avatar
1967 22' Safari
Branford , Connecticut
Images: 11
Smile Oh, good - it found a home!
Originally Posted by flyfshr
Hi Jon -
FF
I think that '66s are identical to '67s which have frameless corning window front and back in addition to the sides. VintageTrailerSupply.com sells these flat windows in addition to the curved ones. I installed one just this summer and it fits very well. Now that repro windows are being made you also see originals on Ebay more reasonably priced that they were before the reproductions came out. Wow! I saw this (maybe twice?) on Ebay too and thought it would go for parts. Glad someone will bring it back to life. Good luck; you came to the right place for advice! Diane
moogie32 is offline   Reply With Quote
Old 12-01-2005, 10:25 PM   #11
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
I was talking to the guy. He had it on Craigslist for a while. I was concidering it to make a covered car trailer out of.
The missing door is the hard part to find and the biggest reason I passed on it. The second reason is no time to deal with it.
If you decide to part it I would like to buy the Reefer scoop.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Refrig fan noise FIXED...really dtbw Refrigerators 264 01-31-2018 05:15 AM
electrical problem ALANSD Mechanics Corner - Engines, Transmission & More... 23 09-13-2015 07:20 PM
Fixed that dump valve !!! 77caravaner Waste Systems, Tanks & Totes 1 05-21-2010 05:55 PM
Problem fixed lbrodsky 2001 Safari 1 12-16-2002 08:42 AM
Rear TV Antenna Outlet lbrodsky 2001 Safari 11 12-15-2002 02:37 AM
