Old 01-03-2016, 08:33 AM   #1
1971 31' Sovereign
Fribourg , Fribourg
buck rivets vs olympic rivets
Hi Airstream Lovers,
I am starting a full renovation of a 1971 31' sovereign
i need to replace all the left side lower panel ( about 35x200 inches)
would be olympic rivets strong enough for that kind of work or should i use
buck rivet like the original construction.
thanks for your help!
Silver Man is offline   Reply With Quote
Old 01-03-2016, 09:02 AM   #2
1986 31' Sovereign
Miami , Florida
If you can use buck rivets, go ahead. A little stronger, lots easier and look like they are supposed to without shaving.
Olympics will certainly work fine (we used a lot of them on aging airframes) but are expensive and require shaving to look like original fasteners. Many assert that they are prone to leakage but I have never seen that problem.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 01-03-2016, 10:54 AM   #3
batman's Avatar
1964 22' Safari
modesto , California
If as you say, you are doing a renovation, and the interior skin is removed. I would buck rivet the panel. No reason to use olympics.
When bucking or using olympics use plenty of your favorite urethane sealant, e.g., Trempro, Vulkem, Sikaflex. On the edges of the panel and the rivets. You will not have any leaks.
Here is something you may find useful for your renovation. Probably the most comprehensive thread about sealants on the forum. http://www.airforums.com/forums/f44/...ry-116214.html
Have fun with your reno.
-Dennis
batman is offline   Reply With Quote
Old 01-03-2016, 02:36 PM   #4
1971 31' Sovereign
Fribourg , Fribourg
the inner skin has been removed, i'll use buck rivets,
Thanks a lot Mike and Dennis for your help!
cheers!
Lionel
Old 01-03-2016, 07:45 PM   #5
ArtisanAir's Avatar
1967 28' Ambassador
1964 19' Globetrotter
1960 24' Tradewind
Edgewood , Kentucky
Make sure you have plenty of beer iced up for your buddy, you'll need one for buck rivets. When driving them make sure your perpendicular as much as possible to prevent the undesirable smile left on the head. It takes practice to get flow going efficiently. It is not about how hard you push either, let the tool do the work, if your tool is jumping off of the head of the rivet try turning the air pressure down to a manageable setting.
Artisan Airstreams
Custom restorations and renovations
www.artisanairstreams.com
Keeping the Art on the road, one project at a time
ArtisanAir is offline   Reply With Quote
Old 03-10-2016, 08:53 PM   #6
AlbertaBound's Avatar
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose , Alberta
The olympic rivets have no shear strength. That panel is structural so buck rivets are a must. Olympic rivets are only for patches and small repairs with no load on them. Compare it to screws and nails... bend a screw and it will break right away whereas a nail will take multiple hits.
AlbertaBound is offline   Reply With Quote
Old 03-11-2016, 06:49 AM   #7
dznf0g's Avatar
Oswego , Illinois
I believe these statements are an over-reach. Olympics do have shear strength......as much as bucked....probably not. (I can't seem to find specs on line) Clamping force? Probably less than bucked. Given a preference, bucked is better than Olympic, but removing half the interior and inner skins?.....a judgement call.
I had two upper end segments replaced 5 years and about 20k ago with Olympics, by JC, due to a backing accident. No leaks, no popped rivets, no seam fatigue.
-Rich-
Old 03-13-2016, 11:52 AM   #8
1975 Argosy 28
1975 Argosy 22
Camrose , Alberta
1/8 solid rivets have 363 lbs shear strength compared to the olympics at 120 lbs. Basically 1/3 the strength. Now since the Airstream used monocoque construction that means the panel holds the weight of the trailer. Your decision...
Old 03-13-2016, 12:49 PM   #9
dznf0g's Avatar
Oswego , Illinois
And the shear strength of the panel edge?
-Rich-
Old 03-13-2016, 02:39 PM   #10
2016 30' Flying Cloud
Oviedo , Florida
I'm sorry, but an Airstream is most definitely not monocoque construction - it has a substantial steel frame and an aluminum superstructure frame the panels are riveted to. While the skins provides stiffness and some torsional resistance, the vertical weight bearing structure for most of the trailer is the frame.
While Olympic rivets can have leakage issues (especially when relying on the gaskets without sealant), I don't recall reading about any widespread issues of sheared rivets. The assertion that Olympics will fail and impact the structural integrity of an Airstream is IMHO hyperbole on a similar or higher level than the assertion that using anything other than a Hensley or PP will result in devastation and death.
I realize it's the internet, but lets try to have a little factual evidence or science before scaring the hell out of the folks that actually believe what they read here
Keith & Barb
2016 Ram 2500 diesel
Southeastern Camping Unit, WBCCI #1675
khollister is offline   Reply With Quote
Old 03-13-2016, 02:52 PM   #11
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
and hopefully we can "move on" now . . . but probably not.
anyway, make sure who ever is running the "bucking bar" on the inside of the trailer is wearing ear protection - I was typically on the outside, and then one day I taught my adult son to use the rivet gun, and I was on the inside . . . next day I was still a little deaf.
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 03-17-2016, 06:34 PM   #12
1975 Argosy 28
1975 Argosy 22
Camrose , Alberta
One last rant
36000 lbs per square inch ... not really an issue
maybe you should read the sales brochure because they sure use the term "monocoque" ALOT!
Agreed!
Old 03-17-2016, 07:26 PM   #13
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Semi-monocoque.
http://airstreaminfo.com/construction/shell-assembly/
SeaLevel is online now   Reply With Quote
Olympic or Buck rivets Joe Little Ribs, Skins & Rivets 13 09-02-2015 06:54 PM
Buck Rivets or Olympic Rivets halimer Ribs, Skins & Rivets 5 09-21-2011 03:20 AM
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 08:33 AM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 10:00 PM
