Old 10-14-2019, 01:18 PM   #1
1972 29' Ambassador
saint louis , Missouri
buck or pop rivet
i'm renovating a '72 ambassador and I am ready to put trim and awning track on. When I did the demo the trim was pop riveted on. Is there a reason pop rivets were used? Can I use buck rivets? or will that deform the trim pieces and awning track
trashbag is offline   Reply With Quote
Old 10-14-2019, 02:32 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Pull type rivets (pop or Olympic) are used in place of bucked rivets when access to the back of the rivet is not available. If you can get to the rear of the rivet to buck it, buck rivets are preferred. They are stronger and cheaper, but require a second person to install.
Richard
azflycaster is online now   Reply With Quote
Old 10-15-2019, 07:39 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Definitely buck the awning rail on. The trim pieces don't matter so much (non structural, and non load bearing), but I would make every effort to seal the pop rivets as I install them.
Old 10-15-2019, 09:14 AM   #4
1972 29' Ambassador
buck rivet it is then. I guess maybe the trim was put on after they finished the interior?
Old 10-15-2019, 09:36 AM   #5
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We used pop rivets on our trim that have a center fill piece to seal them. They are called "closed end pop rivets". If you use regular pop rivets on trim, it just lets water under your skin where you don't want it.
Kay
Buck Rivet Set or Olympic Rivet Shaver Silver.Cabin Airstream Classifieds 1 04-24-2019 07:26 PM
Pop Goes the Rivet or Missing interior pop rivets 22FB Msherw 2005 and newer - Bambi all models 46 02-14-2019 04:57 PM
Can I use a pop rivet in place of a 2 or 3 buck rivets? jackvosney Exterior Restoration Forum 7 10-01-2018 01:52 PM
Buck Rivet and Rivet BigGrey General Repair Forum 5 05-26-2012 10:29 AM
Buck Rivet Tutorial sought TheProfessor Ribs, Skins & Rivets 6 05-27-2010 07:03 PM
