Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum
Old 07-05-2009, 05:57 PM   #1
Profile:  1968 24' Tradewind
Oxford, , Mississippi
Best fix for holes from lock hasp
Need advise on ways to fix the holes left after I removed the riv-nuts where a PO had installed a "deer camp special" (hasp for a padlock). I have 2 holes on the door and 4 on the body of the A/S. I have some 2024 sheeting and thought about making a patch panel and using counter sunk aircraft rivets. I have the interior skin loose around the door to replace the floor so I have access to buck the rivets. I also thought there might be a easier way, I just haven't thought about. The holes are a little bigger than the head of an Olympic rivet.
Thanks in advance for ideas.
Old 07-05-2009, 07:04 PM   #2
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
I would consider filling the holes with some high quality stainless machine screws of an appropriate size.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
moosetags is online now   Reply With Quote
Old 07-05-2009, 07:19 PM   #3
Commercial Vendor
Profile:  Corona , California
I wouls suggest ice looking plates, since you already know the rivet routine.
Seal the holes with Vulkem, before you plate the area.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 07-05-2009, 08:57 PM   #4
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
Add a patch of aluminum with Olympic Rivets which will blend right in with the originals
Pay no attention to the man behind the curtain- WoZ
Need to fix my lock and latch Ultradog Doors & Locks 1 06-11-2009 08:19 AM
New toilet holes don't match old holes RichHog Sinks, Showers & Toilets 8 03-15-2009 07:36 PM
Entrance Door Lock Fix Inland RV Center, In Doors & Locks 76 08-16-2008 06:24 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 08:50 AM
What are the holes for?? Silverfly 1958 - 1963 Overlander 6 09-01-2004 08:09 PM
