Old 03-16-2019, 07:17 PM   #1
camaudio's Avatar
2017 25' Flying Cloud
Carlsbad , California
Exclamation back up camera with out putting holes in AS
we have anAS 2014 flying cloud. I have tried to see if we can get it installed with out putting holes in the trailer at all from the outside that is..
I saw a viedo where a ladys put the camera inside the AS and it was in the back window.. Great idea but we have a screen on the back of ours and the camera is a nice on and so it shows the screen lines to much...
i know I can have it installed on back as everyones does.. but looking to see again if i can not put a hole in the AS as that does invit problems down the line..
thanks all.
Chris M....
camaudio is offline   Reply With Quote
Old 03-16-2019, 07:27 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Can be done easily. Power from Rear Clearance light and mount camera base with 3M VHB
Also I’m sure Robert Cross will chime in he mounted his with high strength Velcro so he could remove the camera in winter storage.
Dept of “OverKill”
Old 03-16-2019, 07:30 PM   #3
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Here is one of Robert’s post.
http://www.airforums.com/forums/f450...ml#post2136166
Dept of “OverKill”
Old 03-16-2019, 08:18 PM   #4
2001 30' Classic S/O
Marshall Ford , Texas
Pull a little of the screen out on the bottom of the rear window. Slip the cable through and attach the camera to the window or frame. Power the camera thru USB or power plug.
John
TexAirS is offline   Reply With Quote
Old 03-17-2019, 10:45 AM   #5
St Petersburg , Florida
Wireless Back up Camerea
OK, this is a really easy fix Go to:
www.tadibrothers.com
and see their offered array of wireless backup camera systems. I installed one by wiring the camera into the tail lamp circuit (no holes drilled...just routed the wire under the tail lamp lens). And that's it for wiring. Camera connects to cab monitor through Bluetooth.
I used industrial adhesive double sided tape (as is used to mount roof top solar panels) to mount the camera.
It requires that the driving lights be on (energized) so the camera gets power, but this is not a bad thing.
My installation has been "bullet proof" in sun, rain, snow, high winds and my total investment was under $150.
Good luck and be well,
Pirate Chris
thanks all.
Chris M....
PirateChris is offline   Reply With Quote
Old 03-17-2019, 12:29 PM   #6
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
I attached the camera to the underside of the rear cabinet and removed the rear window screen. Works great; no problems.
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Floor replacement - c-channel bolt holes slipped 1in off frame holes tshannon Repairing/Replacing Floor &/or Frame 2 07-21-2016 04:07 AM
Putting a hitch on the back of an Airstream mlhenehan Hitches, Couplers & Balls 12 04-22-2013 12:36 PM
Putting black water valve back together mcair Waste Systems, Tanks & Totes 0 09-08-2009 01:33 PM
New toilet holes don't match old holes RichHog Sinks, Showers & Toilets 8 03-15-2009 06:36 PM
putting the belly back on augier Ribs, Skins & Rivets 4 01-29-2009 12:46 PM
