Old 04-17-2012, 06:35 PM   #1
1960 Caravel
Issaquah , Washington
Aluminum
What grade of aluminum was used for the trailers built in 1960. I have some panels that need to be replaced and would like to get as close to original in that respect. Or at least something that can be brought to the same shine. Thanks for your help.
Jake Holt is offline   Reply With Quote
Old 04-17-2012, 06:43 PM   #2
1981 31' Excella II
New Market , Alabama
I believe the older trailers used 2024-T3 Alclad Aluminum. It is a common alloy used on small planes.
2024T3 Alclad Sheet/Strip Aluminum from Aircraft Spruce
Perry
Old 04-19-2012, 03:31 PM   #3
1960 Caravel
Thanks Perry.
Old 05-31-2012, 08:54 PM   #4
1961 24' Tradewind
portland , oregon
I have a 1960 tradewind... cannot find the 2024 t-3 aluminum can I use any other grade ??? It is for the inside of the door thanks Katherine3
artkat13 is offline   Reply With Quote
Old 05-31-2012, 08:59 PM   #5
Eric H's Avatar
1974 23' Safari
1947 25' Spartan , Manor
You can get it here: 2024T3 Alclad Sheet/Strip Aluminum from Aircraft Spruce
Eric H is offline   Reply With Quote
