Old 01-26-2007, 12:47 PM   #1
1969 21' Globetrotter
Gilroy , California
Airstream Letter Logo restoration
Airstream lettering on '69 Globetrotter very shabby looking. Anyone know how the letters are attached and how they can be removed for restoration and then replaced?
dickwhite1 is offline   Reply With Quote
Old 01-26-2007, 01:00 PM   #2
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Greeting Dick-
On the 1969 Globetrotter the Airtream logo was a name plate with a royal blue background and silver letters. You have two options; one is to replace the plate which and be purchased either through Vintage Trailer or the Airstream shop at JC, or others have done a wonderful job of restoring the originals. Use the search function and you will find a few threads on how to do it yourself. Good luck and please post a few photos!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 01-26-2007, 01:09 PM   #3
1970 25' Caravanner
Rutherfordton , North Carolina
Number on each end of a/s
I am a Newbee, Can anyone tell me what the numbers on each end of my a/s stand for and what does all the other number I see stand for? I have seen AIR#!!!!!!! and some other also.
steve hughes is offline   Reply With Quote
Old 01-26-2007, 01:12 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Which letters? Front? Back? These images belong to Vintage Airstream Home. Can you post some closeup digital pics?
[on edit: It looks like that may not be original to the model. Let me work a bit further...]
5 meter Langford Nahanni
Old 01-26-2007, 01:17 PM   #5
Think Rick's talking about this style. Which do you have?
Old 01-26-2007, 01:24 PM   #6
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
The RED numbers are the WBCCI membership numbers of the previous owners. If you look in the WBCCI Forum, you'll find lots of info...mostly good but some bad too. We are members...and look to the club continuing on another 50 years!
If they are BLUE, they are the previous owner's AirstreamForum membership number (or Air#)...although that is a relatively new badge to be sporting...the forum is only 4 years old.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 01-26-2007, 01:34 PM   #7
2005 22' Safari
1960 24' Tradewind
Canoe- thank you for posting the photo! I should have thought of that. Thanks for the backup!
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
Old 01-26-2007, 01:35 PM   #8
Gilroy , California
I have actual individual 3-D letters on a 69 Globetrotter. The name plate logo ended the year before in 68 and was simply riveted on. Trying to dtermine how to remove and then reinstall the actual letters.
Thanks!
Old 01-26-2007, 01:58 PM   #9
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
If they are like my '73, they have a threaded rod welded to the back of them (2 or 3 of these per letter). Inside the wall of the camper, there is a nut on the rod. All of this is covered in a heavy layer of Vulkem. I've got a picture or two in my Full Monte thread. Problem is that the only way to remove them is to to remove the inner skins, which means taking out a bunch of other stuff first.
If you simply want to "restore" them, you should be able to clean them very well and repaint them. Rustoleum "Royal Blue" is the color, IIRC. As small as mine are, I'm simply going to brush paint them (VERY carefully).
Hope this helps a bit.
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
Old 01-26-2007, 02:07 PM   #10
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
My PO hand painted mine - they turned out nice. I suppose it takes a steady hand though.
Dave
Fyrzowt is offline   Reply With Quote
Old 01-26-2007, 02:14 PM   #11
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Jim, you can actually access the back side of these without removing the inner skins...at least in '73. I would imagine '69 would be the same.
the inner part of the cabinet over the gaucho can be removed without removing the endcap; pull the insulation out, and you can access the back side of the marker lights, and the back side of the letters.
now...as to how to get them un-attached and re-attached...don't know about that. I'm pretty sure I read somewhere (service manual?) that the factory method is to just cut off the rivets by using a putty knife slipped behind the letters from the outside, then whack with a hammer to break them; then drill a big ugly hole in the face of the letter, pop-rivet them back in place, paint over the rivet, and hope nobody notices.
I'd opt for your method, first. I don't really know exactly what is holding them on from the back, because as you pointed out, each stem is covered with a big glob of vulkem.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 01-26-2007, 02:15 PM   #12
1970 25' Caravanner
Thank for all the enfo. My numbers are red and are made of some kind of cloth. I will look futher in the forum.
Old 01-26-2007, 02:20 PM   #13
Fyrzowt's Avatar
Images: 8
Steve,
If you have any way to post a photo of this please do. I don't think we're all talking about the same numbers.
Dave
Old 01-26-2007, 02:31 PM   #14
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Those are old, decaying decals...the PO's wbcci membership number. You can remove them using a wet rag and a steam iron...and a plastic putty knife. works like a charm...
The original poster was talking about the airstream logo letters.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 01-26-2007, 03:30 PM   #15
They look like this from the inside. You are looking at one of those odd-ball nuts that I've cleaned the Vulkem off of, one of the studs that broke off below it, and several that have either new or old Vulkem on them.
Name:	Front reseal 8.jpg
www.nesa.org
Air No. 6427
Cost to restore a gutted Airstream Draco General Interior Topics 28 02-18-2013 11:17 PM
future airstream motorhome betteleal Airstream Motorhome Forums 11 02-12-2005 01:39 PM
Late '80s Airstream Aluminum Fifth-wheel acwdgw Integrity 5th Wheel (all Years) 17 01-09-2004 10:20 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 01:31 PM
