Old 04-24-2018, 09:51 AM   #1
1975 27' Overlander
Lubbock , Texas
A-Frame to Skin Trim Piece
This is my first post, but this forum has been an invaluable resource while restoring my 75' 27ft International Overlander. I am looking for the plastic trim piece that shrouds the A-frame members where they meet the skin. I have tried searching on VT Supply, Silver Trailer Supply & ODMRV to no avail. I have attached a couple photos of mine from the frame-off phase. They appear to be in good condition, but when I removed them, they crumbled from decades of UV damage. Thanks to everyone in advance for your help!
Name:	Mitty Trim 1.jpg
ID:	309446   Click image for larger version
Name:	Mitty Trim 2.jpg
FreeRenegade is offline   Reply With Quote
Old 04-24-2018, 10:18 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums.
That part is known as an A Frame Closeout, and has been NLA for many years.
Old 04-24-2018, 10:33 AM   #3
1975 27' Overlander
Lubbock , Texas
DIY Solution
Thanks for the info! Now I know that I will need to come up with another solution. Has anyone else had the same dilemma, and what did you come up with for making this look good while also sealing this joint from water infiltration?
Old 12-06-2018, 10:26 AM   #4
1971 31' Sovereign
Palm Desert , California
I just found this old post.
I bought a pair of NOS A-frame closeouts on eBay a couple of years ago. They were expensive but I needed them. I’ve yet to install them.
If they are NLA and nobody is making them I’ll look into having them reproduced if there’s a need.
CaCraig is offline   Reply With Quote
Old 12-06-2018, 12:51 PM   #5
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
There is another thread on these forums where someone was looking into having some made via 3D printing and was gathering up interested parties, but as I recall, nothing came of it.
Old 12-07-2018, 12:03 AM   #6
1971 31' Sovereign
That was probably also mine. I got some quotes on 3D printing but they were really expensive. Now I’m going to look into thermoforming plastic.
Old 12-07-2018, 05:28 AM   #7
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Get someone to bend and cut to match profile two pieces of 1/8” aluminum and tigweld them together. Would not be a hard project.
Old 12-11-2018, 11:42 AM   #8
1975 27' Overlander
Lubbock , Texas
Get someone to bend and cut to match profile two pieces of 1/8 aluminum and tigweld them together. Would not be a hard project.
My thoughts exactly. I ended up taking some scrap alclad aluminum sheet and making these pieces myself. It actually turned out better than the original plastic. It takes a little time to get the curve right, but well worth the time!
Old 12-11-2018, 12:07 PM   #9
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
FreeRenagade, Can you post some pics of your aluminum frame trim pieces to see how they turned out.
cole3444 is offline   Reply With Quote
Old 12-26-2018, 06:41 PM   #10
Kelowna , British Columbia
Also interested to see how aluminum would work for these closeouts.
dherder is offline   Reply With Quote
I need a piece of belt-line trim... malconium Clearcoat, Exterior Paint & Trim 14 09-28-2017 11:01 AM
Looking for a piece of lower trim on a '73 argosy VonLuck All Argosy Trailers 6 06-12-2011 07:37 PM
Is the trim piece between the endcaps and the ceiling still available? ronstory General Interior Topics 9 08-13-2009 09:22 AM
Can we replace floor piece by piece? tdturn2 Repairing/Replacing Floor &/or Frame 5 06-22-2009 07:54 PM
