Old 06-03-2016, 04:53 PM   #1
1976 Argosy 28
Atlanta , Georgia
76 Argosy Molding (Rub Rail)
Hey Airstreamers!
Question: I am missing 22 feet of the bottom rub rail on my Argosy. It's the backside. I see the part I need on VTS, (comes in 8ft lengths). However, should I get the Butyl Putty Tape to help seal or go with TremPro 635 and just calk it. Or both. This is a huge area where I have found our leaks. I removed the front rub rail to get to the front belly pan and the removed the old tape. Since this is the seam between the camper and the frame, figured it was pretty important to get right.
Thanks.
this is the rubrail btw http://www.vintagetrailersupply.com/...p/vts-2205.htm
nocmanus is offline   Reply With Quote
Rub Rail, Rub Rail 'where art thou?' Radman Clearcoat, Exterior Paint & Trim 18 08-09-2017 08:27 PM
Argosy belt line/rub rail end caps bkahler Argosy Motorhomes 3 10-12-2012 06:01 PM
Argosy rub rail inserts J&G22argosy Clearcoat, Exterior Paint & Trim 1 05-19-2006 11:35 AM
rub rail on ebay for argosy wb13798 Airstream Motorhome Forums 7 05-03-2004 08:29 AM
