Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum
Old 12-11-2017, 07:04 PM   #1
Steamgauge
1966 24' Tradewind
Bonney Lake , Washington
'66 Tradewind frame
Does anyone have a picture of the frame for a '66 tradewind? I need to know if it has a sill plate in the back, the back of the shell was cut out of mine as you can see from an earlier post. Pictures of the frame alone for 66-68 would be helpful.
steamgauge is offline   Reply With Quote
Old 12-12-2017, 06:24 AM   #2
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Detroit , Michigan
'66 Tradewind frame
1968. Click image for larger version
Note the rear most crossmember was removed in the above image. Here it is still attached.
Brian's AS renovation:
https://www.airforums.com/forums/f11...on-134984.html
Tow vehicle: 2019 F250 Lariat 6.7L CC SRW
Atomic_13 is offline   Reply With Quote
can a frame be repaired without frame off restoration? RhinoWW Repairing/Replacing Floor &/or Frame 12 10-29-2014 10:46 PM
Frame Rot - New Frame jcawley1 Repairing/Replacing Floor &/or Frame 3 09-01-2014 08:30 AM
Advice on gaucho/jacknife frame frame & wall remodel chiefbrody General Interior Topics 0 01-30-2013 04:38 AM
Beatrice era frame experts if you please. Odd frame issue Kevin245 Repairing/Replacing Floor &/or Frame 5 08-25-2012 09:55 AM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 05:55 PM
