Old 09-13-2006, 07:24 PM   #1
2007 23' Safari SE
Charleston , West Virginia
Water Tank Draining
I found the plastic valve to drain the water tank but I also noticed another copper valve near the plastic valve which I opened. Only about a pint of water came out of the copper valve. What is this valve?
Also, I never found the valve to drain the hot water tank under the carriage?
Jim Triplett
trippy is offline   Reply With Quote
Old 09-13-2006, 08:31 PM   #2
leander , Texas
there should be two other copper drains in addition to the fresh water plastic tank drain. one is for the cold water low point drain, and one for hot. these have nothing to do with the hot water heater. the drain for that is in the on the front of the heater. just open the access panel and there is a small drain much like the low point drains. open that and the pressure relief valve to drain it.
mastercaster is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 06:16 PM
No Grey Water Tank????? Anna Waste Systems, Tanks & Totes 16 11-17-2002 08:33 PM
Pressurized water tank eracism Fresh Water Systems 2 10-25-2002 07:09 AM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 09:36 AM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 11:28 AM
