Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2007 Safari
Old 05-16-2008, 04:37 PM   #1
Profile:  2007 20' Safari
Dayton , Ohio
20' Safari... 1000 lb bars ok? what is ceiling stain??
Hi,
New member here. Own two year old 20' Safari. But, not new to RVs and trailers.
Hope posted this in correct area on this site. Bear with me.
Questions:
1. I am using the 1000 lb bars from my last heavier Holiday Rambler trailer on my 20ft Safari. Would dropping down the size of the bars help the "banging" around the trailer takes?
2. If so, what size drop down to? since most hitches are "idiot proof" meaning you cant use smaller rated items with wrong hitch etc. Will I have to purchase bars and receiver portion for my hitch as well?
If change to lower rated bars, will the lower rated bars fit in my hitch?
3. And, there is a stain developing on the ceiling area of the bathroom wall. Looks like black metalic stain -- like graphite of some sort. I suspect it is from the rubbing of two metal parts above the ceiling material or rubbing of a rivet in that area. Is this correct? If so, what is correction (if any)?
thanks.
OhioMarty
OhioMarty is offline   Reply With Quote
Old 05-16-2008, 04:46 PM   #2
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road , Fulltiming
Images: 52
Hi, welcome to the forums. The 1000 pound bars are probably too heavy duty for your trailer, 750's would be a much better choice. The black stain is from aluminum moving, and could be made worse by the heavier bars you currently have. A picture of the stain would help the detectives here.
BTW, what kind of "truck" is your tow vehicle? That will also help as far as WD bar recommendations.
You repair things with tools. You fix things with a hammer.
AIR#2611
Old 05-16-2008, 05:32 PM   #3
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Let us know the hitch weight of your trailer and the vehicle you are pulling it with. I can attest that 1,000 bars are most likely way to heavy.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 05-16-2008, 05:34 PM   #4
SilverRanger's Avatar
Profile:  2005 19' Safari
1968 24' Tradewind
Milton , Delaware
Aluminum Dust
My 2005 Bambi has the same issue. I was told by Jackson Center that it was caused by the panels flexing behind the fabric where they are joined by rivets. Their first suggestion was to vacuum it out. That only made it worse. If that's the case with your 2007, Terry is right about heavy bars increasing the problem.
For what it's worth, Airstream said it was covered by the warranty. My dealership apparently lacked the expertise to repair it, so it would have meant a trip to Ohio. I would have taken them up on it but at that stage, I had already had the trailer at the dealership awaiting repairs more than it was at home, and I just wanted to go camping. If you find a solution without involving an Airstream repair facility, please let me know.
Best of luck.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WBCCI# 4582
WDCU
SilverRanger is offline   Reply With Quote
Old 05-16-2008, 05:34 PM   #5
2008 Safari 27 FB SE
FordTruck's Avatar
Profile:  2008 27' Safari FB SE
Lynchburg , Virginia
We had 750's for our '03 22ft International and they were quite enough. We upsized to a Safari 27 FB SE earlier this year and still use the 750's. Rides and tows like a dream.
FordTruck
2005 F-150 5.4L Supercab 4X4 (Betsy 3)
2008 Safari 27FB SE (Arvin as in RV'ing)
2006 Harley Davidson Electra Glide Classic
FordTruck is offline   Reply With Quote
Old 05-16-2008, 06:47 PM   #6
Profile:  2007 20' Safari SE
Madison , South Dakota
I use 750's with my 20' and they work fine. Wouldn't want to use anything less.
Al - K4GLU is offline   Reply With Quote
Old 05-16-2008, 07:22 PM   #7
Profile:  1971 23' Safari
Groveport , Ohio
Images: 18
Gee now I'm worried, I hope this is not a hijack. My trunnion stlye bars are not marked that I can see but I've been told they are #1000 pound bars. A 1999 1500 suburban and 71 23' safari with I think 400 pound tounge weight. Should I have 600 or 750's. Or how can I tell for sure what I have now. Robert
bertro is offline   Reply With Quote
Old 05-16-2008, 07:33 PM   #8
Commercial Vendor
Profile:  Corona , California
Robert.
Measure the width of the bar, as it goes into the trunnion.
1" = 550 #
1 1/8" = 750 #
1 1/4" = 1000 #
You should be using 550 bars. 750 is ok, IFthey bend at least 1 inch, preferably 2 inches.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Inland RV Center, In is online now   Reply With Quote
Old 05-16-2008, 07:40 PM   #9
Dayton , Ohio
Many thanks for the information. By the way: I live close to the Jackson Center plant. Have notified Chris there about the developing stain on ceiling. He noted it and told me would be covered under warranty, even though by the time we get back such will be expired.
My hitch weight (per manual) is 600 lbs.
Tow vehicle is Dodge Ram 3500. Yes big truck for small trailer. But used this large truck to tow a LARGE holiday rambler trailer.
I will go to camping world in the morning in search of 750 or 700 lb bars. If not will go to other trailer dealer(s) in area. Now in Bay Area, CA
Found out that have to change the part where "stubs" fit into my hitch. The lighter weight rated bars DO NOT fit into the heavier rated bar slots -- hope that makes sense.
Again, thanks
Old 05-16-2008, 07:52 PM   #10
Commercial Vendor
Andrew T's Avatar
Profile:  2007 34' Classic
London , Ontario
Hi Marty
I think your problem is more likely the 3500 suspension than the 1000 lb. bars. We have not seen this problem in any or our customers 20's but they are all towing with softer tow vehicles.
What pressure are you carrying in your truck and trailer tires. What year is your 3500 and is it a 2 or 4 wheel drive.
Do you have another car at home?
Andy Thomson
Airstreamer since 1968
Can-Am RV Centre
The Towing Specialists
London, Ontario.
Andrew T is offline   Reply With Quote
Old 05-16-2008, 08:04 PM   #11
Dayton , Ohio
Andy, have 2005 Dodge 3500 diesel, SRW, 2 WD, 8' bed, four door.
No other add on's such as air bags etc.
Have to check psi on truck and trailer. I maintain psi on trailer tires as specified on tires....believe around 60 psi. Rated to 65 psi.
Drop psi on trailer tires?
When I was at jackson Center and Airsteam dealer, both told me that 1000 bars were "ok"
BTW: I have high regards for Chris, Kevin and the rest of the crew at the factory. They have been very helpful. Done excellent work. Pleasure to deal with. They are a good crew there.
Old 05-16-2008, 08:10 PM   #12
Images: 52
You really have too big a truck for the WD bars you have. I think if you can find them, the 500 pound or so bars would be much better. Do you carry anything else in the bed when you tow? Motorcycle? Generator? Mother-in-law?
I found my 3/4 ton truck tows and rides best when I have the trailer, and about 400 pounds of "stuff" in the bed. Airstreams respond more positively to a softer-sprung vehicle. Do you have a smaller vehicle you could set up to tow?
BTW, Camping World will likely not have anything less than 1000 pound bars, but you can try them anyway.
AIR#2611
Old 05-16-2008, 08:20 PM   #13
Groveport , Ohio
Images: 18
Thanks Andy, I will be getting 550's before I tow for Memorial weekend. Mine are 1000's. Robert
Old 05-16-2008, 08:26 PM   #14
Dayton , Ohio
Overlander,
yes, carry lots of items (weight) in bed of truck: two EIU generators, two containers of gas (sometimes), tools, large solar panel set up (stored under a false bed made of 3/4" plywood), bike, paint, oil, lube, hiking and camping gear, and lots of other things etc etc. So weight in bed of truck.
I called Camping World they sell 800, 700 and 600 lb bars. It was too complicated talking to them on the phone...so best to go out in person in the morning
I will look at Camping World and at trailer dealer in the morning for 500 lb bar.
I try to keep the loaded weight of the tailer down by draining most of the water from fresh, black and grey tanks. Not alot of can goods etc in the trailer.
Do you think by carrying more water in tanks would help? (adding weight to trailer may stop the pounding around???)
mmmm or even have truck shocks, and or trailer shocks, checked??
Biggest question: can I wait to change bars until I get back to Ohio? Now in california.
Pingbacks are On
Got our new 20' Safari SE Wayne&Sam 2007 Safari 9 07-20-2008 11:34 AM
Stabilizer Bars 63 Safari donbara Hitches 1 04-27-2008 07:33 AM
Tundra 4.7 vs. 5.7 for a 20' Safari marta5 Tow Vehicles 21 02-20-2008 11:17 PM
2008 20' Safari SE Jeff Evans Member Introductions 12 10-31-2007 07:08 PM
All New 2006 Safari 20' NeatAirstream The Vendor's Forum 32 04-17-2006 11:44 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
