Old 06-09-2017, 05:22 AM   #1
cashdaddy's Avatar
2007 25' Safari FB SE
Rocky Mount , Virginia
How do I turn on this furnace???
The off switch seemed to be stuck on the far right. Not seeing how to turn it on at all.
cashdaddy is offline   Reply With Quote
Old 06-09-2017, 05:29 AM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Mine feels stuck, but isn't. It takes a pretty hard push to move the switch to the on position.
CRH is offline   Reply With Quote
Old 06-09-2017, 05:48 AM   #3
cashdaddy's Avatar
Thank you. That worked! You're a genius .
Old 06-09-2017, 05:53 AM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
No problem.... I feel certain that lever is gonna break every time I snap it over, but it never does.
Old 06-09-2017, 02:48 PM   #5
2014 22' FB Sport
Sacramento , California
I agree---I didn't dare to force the lever the first time---thought I would break it. It does take a lot of pressure.
rkutect is offline   Reply With Quote
Old 06-09-2017, 04:17 PM   #6
sb55's Avatar
2018 30' Flying Cloud
South Hero , Vermont
I have this same thermostat and the on/off is stiff. Has anyone changed it out to a more precise digital version?
Is it plug and play wiring, or is a RV voltage different?
sb55 is offline   Reply With Quote
Old 06-09-2017, 06:51 PM   #7
1999 25' Safari
Sparks , Nevada
I replaced one just like that on my 1999 Safari. I used a Honeywell model 44250 that I had removed when upgrading my home heater. The digital thermostat keeps a much tighter on/off temperature. I like not having the wide temperature swings in the trailer.
Vic H
Vich is offline   Reply With Quote
Google Turn-by-Turn Navigation techiej Electronics & Connectivity 19 12-27-2012 05:55 AM
thermostat will not turn on furnace, bypas will batt Furnaces, Heaters, Fireplaces & Air Conditioning 13 04-30-2012 11:55 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
Furnace did not turn on Kumon22 Off Topic Forum 7 02-22-2010 03:57 PM
