Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2007 Safari
Old 10-12-2009, 08:26 AM   #1
Profile:  2007 20' Safari
Chgo. N.W. Burb's , Illinois
Fresh water Drain
Iv'e seen this before and can't relocate the fix. The Fresh Water Drain has been Terrible since day one. Now it's out of warranty and i can't live with it . How can I replace the Fresh water Drain.I think one was a Metal indtead of Plastic Drain.
Thank you in advance.
knunut is offline   Reply With Quote
Old 10-12-2009, 08:45 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Hi Ken. john hd replaced his with a similar plastic one - fresh water tank plug and valve repair
A friend bought a new 2008 this year and his plastic drain sure is tight. Some of these are just bad and I don't know why.
What did you find out about your leaking exhaust hood vent?
Old 10-12-2009, 02:15 PM   #3
RE: Exhaust Vent
I havn't been able to duplicate the cause (We were duing 65mph in Rain)
I did however hold open the grey vent flap, cut and installed Foil Duct tape in the Duct Exhaust vent. Found Lot's of Gap's.
I also found the Black Foam that you install in your home Gutters to keep the Leaves out. I cut a piece to length and at an angle to fit up in the vent cover area. I install it during transit and it keeps the flap Down and leak free.
The little plastic "wings" don't seem secure it enough.
While doing this i found a "Clip" that was preventing the internal flap from opening all the way.(Not mentioned in any manual's) I pulled this,and now the Exhaust Vent Flaps open "ALL" the way and there are less "Smoke " alarm's while cooking !!.
Old 10-12-2009, 05:19 PM   #4
Profile:  2009 23' FB Flying Cloud
Madison , South Dakota
You can make the plastic water drain work much easier by by removing the rotating part and lubricating it with something like vaseline. Although I haven't done that with the Airstream yet did this when I had my Casita and it made the valve much easier to turn.
Al - K4GLU is online now   Reply With Quote
Old 10-12-2009, 05:30 PM   #5
wilkeytn's Avatar
Profile:  2008 23' International CCD
Nashville , Tennessee
I had Airstream of Arkansas replace mine with a metal one THE BEST UPGRADE YET, call Bill in service he can tell you about.
wilkeytn is offline   Reply With Quote
update on fresh water drain billiards Fresh Water Systems 0 07-13-2009 10:57 PM
Fresh Water Tank Drain NEW94 Fresh Water Systems 5 11-04-2007 09:58 PM
Fresh water drain valve nilesrob Fresh Water Systems 3 11-10-2006 09:23 PM
Fresh water drain ? TexasStars Fresh Water Systems 6 10-29-2003 01:09 PM
Fresh water drain Happycampers Fresh Water Systems 0 07-21-2003 05:54 PM
