Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2007 Safari
Old 07-22-2007, 08:01 PM   #1
gowyn's Avatar
Profile:  2007 27' Safari FB SE
London , ontario
Electrical outlet on 27FB
Waiting to pick up our new 27FBSE. I plan on installing an under counter hot water heater with a spigot. Previously was installed in our 19' Bambi where I cut a hole to run the electrical cord out from under the sink to an outlet on the wall.
Does anyone with a 27FB know if there is an outlet behind the stove or 110v near the sink area. Would prefer not to see the cord which is only about three feet long.
BTW, we do NOT have the conv/micro instead of the gas oven.
Thanks.
gowyn is offline   Reply With Quote
Old 12-16-2007, 06:32 AM   #2
gowyn's Avatar
London , ontario
I'll answer my own question just in case anyone else needs to know. Behind the gas stove there is a 110v outlet, for the microwave I assume. So I guess you could remove the gas stove and install a conv/microwave in there instead.
Old 12-16-2007, 10:13 AM   #3
2008 Safari 27 FB SE
FordTruck's Avatar
Profile:  2008 27' Safari FB SE
Lynchburg , Virginia
Hi Gowyn
We just signed the papers for our 2008 Safari 27FBSE. It is on the dealer's lot but we're not taking possession until after 1/1/08.
Ours has the Microwave in the middle section of the pantry to the left of the stove. I was going to suggest you look for where they made a connection possible but you beat me to it with your detective work.
Hope you enjoy your's as much as we're looking forward to time in ours.
FordTruck
2005 F-150 5.4L Supercab 4X4 (Betsy 3)
2008 Safari 27FB SE (Arvin as in RV'ing)
2006 Harley Davidson Electra Glide Classic
FordTruck is offline   Reply With Quote
Old 12-16-2007, 10:40 AM   #4
cameront120's Avatar
Profile:  1972 25' Tradewind
Are there any spare circuits on your breaker panel that you could hard wire it into, rather than take up an outlet?
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 12-16-2007, 01:39 PM   #5
gowyn's Avatar
London , ontario
Been a while since I hooked up the water heater but as I recall there was hardly anything on that circuit. Also the heater was 5.6A max I believe.
Ran the rest of the summer with it plugged in. Gotta love that hot water on demand, beats boiling the kettle all the time.
Pingbacks are On
electrical problem ALANSD Mechanics Corner - Engines, Transmission & More... 22 08-22-2002 09:47 PM
Help!! exterior outlet cover stuck DIMMER Electrical - Systems, Generators, Batteries & Solar 8 06-28-2002 11:04 AM
Waste Water Outlet Valves Danno Waste Systems, Tanks & Totes 2 06-18-2002 10:48 AM
Exterior 120 volt outlet cover thenewkid64 Electrical - Systems, Generators, Batteries & Solar 8 06-16-2002 08:54 AM
New electrical in position FrankR Electrical - Systems, Generators, Batteries & Solar 5 05-18-2002 11:47 PM
SEO by vBSEO 3.1.0
