Old 11-18-2012, 05:40 PM   #1
2007 28' Safari
Hillsboro , Texas
Dimming lights
when connected to shore power and using my Parallax power supply model 7300, my interior lights dim excessively when I turn on my 12vdc water pump. I have check my grounds and need some ideas.
zestojo is offline   Reply With Quote
Old 11-18-2012, 05:56 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Check the battery condition, voltage and connections. You sttill need a good battery when hooked up to shore power.
What happens when you are not hooked up to shore power?
Old 11-18-2012, 06:12 PM   #3
Ottawa , ON
Not really, especially with a modern 120 to 12 V converter. I never use a battery when our TT is parked for an extended time (which, since the birth of my grand-daughter has been years ).
I would check to see if any connections to or on the water pump are corroded, or if the pump itself is defective.
It has a reasonably hefty draw, IIRC, so some dimming is to be expected...
Old 11-18-2012, 06:24 PM   #4
2007 28' Safari
Hillsboro , Texas
that is correct. with this parralax unit, the manual says to disconnect the batteries from the circuit when using shore power. I will check my pump to see if it draws too many amps.
Old 11-18-2012, 06:36 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Now thats unusual...I've only heard of isolating the batt's during storage when NOT plugged into SP. Never heard of using the converter as a direct power supply, unless an emergency batt failure, or for short duration when the batt's are out during storage.
How do you charge 'em?
Old 11-18-2012, 06:38 PM   #6
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
Lumatic is Correct...
... and so are you, zestojo.
If you have a failing battery in the circuit, it will cause the symptoms you describe.
If you have disconnected the battery, then it can only be blamed on the pump drawing too many amps (on top of everything else you have turned on, right at that moment).
You may have simply reached the "point of culmination."
How many amps is your Parallax?
Ken L
2019 Flying Cloud 27FB
2018 GMC Yukon Denali XL
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 11-18-2012, 06:39 PM   #7
Alumaholic's Avatar
Images: 36
Concur
I wouldn't purchase a converter with that caveat.
Ken L
