Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2007 Safari
Old 01-24-2008, 05:04 PM   #1
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Bad thing to do to an Airstream....
Don't know about you, but this is just screaming problems over the long term.....
eBay Motors: 2007 AIRSTREAM SAFARI 25FT NEVER USED NO RESERVE (item 230214843941 end time Jan-26-08 11:02:02 PST)
Take a peek at the back bumper to see what I'm talkin about....
Old 01-24-2008, 05:10 PM   #2
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road , Fulltiming
Images: 52
Looks like buyers are bidding accordingly.
You repair things with tools. You fix things with a hammer.
AIR#2611
Old 01-24-2008, 05:17 PM   #3
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
I know the guy who owns it!!!
I just passed by it in the RV park I was in an hour ago and yes.....it truly is a hatchet job.
The welding and finishing are actually done rather well, but the engineering and frame extension are so far off-base and so wrong for the monocoque construction of an Airstream, that just the weight of the box alone will cause some serious problems with this trailer.
I personally wouldn't touch it, and it was offered to me for less than I can sell my '06 19CCD for. NO THANKS!!!!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
lewster is online now   Reply With Quote
Old 01-24-2008, 05:21 PM   #4
soldiermedic's Avatar
Profile:  1975 29' Ambassador
O'fallon , Missouri
Looks like it is set on full hookups and has had a box welded to it.
Looks USED to me.
Steve
Streaming Soldiers Blog
Silver, Stars, and Stripes All-American Forums Rally
21-24 AUG 2008 at Meremac State Park, MO
Get your reservaions at 1-877-422-6766
Sign Up Page
soldiermedic is offline   Reply With Quote
Old 01-24-2008, 06:28 PM   #5
Profile:  1967 26' Overlander
Winston Salem , North Carolina
I give the unit 5 years till frame separation.
Greg
Winston Salem, NC
WBCCI 5218,
1967 Overlander International.
FTC 15771
1979 Avion 30ft rear bath
Silverwanabe is offline   Reply With Quote
Old 01-24-2008, 06:35 PM   #6
2airishuman's Avatar
Profile:
we covered this unit a few weeks ago...
Rear Bumper Cargo
is this a relist or is the auction still going?
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 01-24-2008, 06:38 PM   #7
Mrs_RedSHED's Avatar
Profile:  1985 31' Excella
Columbus , Indiana
Suppose it has not been on the road much since the addition of the rear tool box. Could the box potentially be removed and the frame (etc) restored to maybe not original condition but to a condition where it will not damage itself and the trailer further? If it could, then would the price be a fair one?
BTW: We are not shopping at all, the question just occurred to me.
Mrs_RedSHED
Mrs_RedSHED is offline   Reply With Quote
Old 01-24-2008, 06:38 PM   #8
Kajtek1's Avatar
Profile:  1965 22' Safari
Orinda , California
I might shock you guys with what I am carrying on the rear of my motorhome.
Dry PWC is 480 lb. Bars and lift over 150.
Kajtek1 is offline   Reply With Quote
Old 01-24-2008, 06:38 PM   #9
Images: 52
Is that "static" or "towed" time?
AIR#2611
Old 01-24-2008, 06:44 PM   #10
Profile:
Originally Posted by Kajtek1
I might shock you guys with what I am carrying on the rear of my motorhome....
shocked, no.
disgusted...YES!
i need welders glasses just to look at that color scheme!
cheers
2air'
btw can it be launched with a driver directly into the water?
Old 01-24-2008, 06:47 PM   #11
Images: 52
Maybe he was trying out for the role of stunt double for "RV"...
AIR#2611
Old 01-24-2008, 06:50 PM   #12
Kajtek1's Avatar
Orinda , California
Let me guess? Too much silver?
I build the bars for other (higher chassis motorhome) and have cable lift for lowering PWC. With this motorhome on most of the ramps when stopping the wheels on the edge of the water, the PWC is already partly in the water. All it takes is a push to slide it down on the water. I can do it with you sitting on it.
Old 01-24-2008, 07:40 PM   #13
Commercial Vendor
lewster's Avatar
MoHos regularly take 1000lb tongue loads to their very beefy frames....... no probem. I see lots of motorcycles on heavy elevator type ramps being used....and safely! Airstream trailers do not have the frame design, section width or strength to hang ANYTHING from the rear bumper. It's a recipe for disaster!
AIR # 10325
Old 01-24-2008, 07:59 PM   #14
Kajtek1's Avatar
Orinda , California
Not exactly the same situation, but my Safari was hanging on the bumper for over 20 years. The tires were flat, so they supported next to nothing. On the top of that the PO dumped about 4 tons of books inside. When I was pulling the trailer from the jacks, the corner siding had stressed dents, that smoothed out after setting the trailer on the wheels.
So with 3500 lb trailer weight and 8000 lb of books what was the load on bumper frame?
How much would you say the box weight?
Aren't you having any faith in Airstream?
Pingbacks are On
Airstream Dealers=bad parts service moisheh The Vendor's Forum 7 01-30-2008 04:59 AM
HELP Airstream Bad Frames??? lanajane Repairing/Replacing Floor &/or Frame 1 04-25-2007 09:12 AM
Airstream 1979 bad rear bumper design wacnstac Bumpers & Bumper Storage 15 07-07-2006 06:33 AM
Bad case of Airstream fever kudzu Member Introductions 14 05-09-2006 06:27 AM
Bad Experience at the Minnesota Airstream Park 6xblessd On The Road... 33 08-29-2005 12:08 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
