Old 05-17-2008, 08:47 AM   #21
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I agree. Go with the 500s or 600s. I use to tow a 19' and a 25' with my softer suspension sedan and had 1200lb bars. There was lots of flex in the bars and it worked great. When I upgraded to a 3/4 ton truck, the 1200lb bars were nothing more than dead weight. They had no flex to them. After reading on this forum, I learned that I was way overhitched. So I went down to the 800lb bars, much better, but then tried the 600lb bars and was even better than the 800lb bars. Now with the 25', I have the dual cam sway, so having some bend/tension on the bars is key. With 600lb bars, life is good. I have about between 750 and 875lb hitch weight (750lbs by the specs) based on a hitch scale I bought.
I bought my bars off eBay. It's hard to break weight bars, but I suppose it can happen. Also the bars are available online from many vendors and I would feel pretty comfy in saying, buying bars off eBay or new via an online Reese shop would cost less than it would at Camping World.
Old 05-17-2008, 02:49 PM   #22
2007 20' Safari
Dayton , Ohio
Well, went to Sierra Truck and Van, Fairfield, Ca, 707-864-1064 today and got set of 550# bars. Since my ancient Reese 1000 # bars would not work with new Drawtite 550 # bars, had to buy new weight dist heard and deep drop shank as well.
Which is not a problem because my old 1000 # set up can sit in garage incase ever buy a heavier trailer (i.e. Holiday Ram)...but dont think so.
Thanks to all who gave me suggestions and help.
OhioMarty is offline   Reply With Quote
Old 05-17-2008, 04:06 PM   #23
Please post your opinion, for the benefit of others, once you use the new rating bars.
Old 05-17-2008, 06:17 PM   #24
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Well Andy, I hope I will be better off. The local dealer gave me some new reese 750's for $42.00 w/exchange of my very old #1000's. He had a pair of 550's but 1 in the pair was drawtite the other a reese, he said it didnt matter but I didnt like that program. My 1/2 ton 4x4 suburban is a soft ride in the rear so I hope I these #750's works out. Thanks for the tips. PS why dont you open up a store in OH. it sure would be nice. Robert
bertro is offline   Reply With Quote
Old 06-06-2008, 11:25 PM   #25
2007 20' Safari
Dayton , Ohio
Follow up to my original post about bars and stain...
This is a follow up to my original post.
I installed 550 lb bars and they seem to do better job than the heavy duty 1000 lb bars I was using.
Chris at factory told me they will take care of the stain on ceiling (bathroom wall) when I come to Ohio.
As always, Chris and Kevin do a good job of helping customers.
Also, thanks to all who commented on my original post.
Got our new 20' Safari SE Wayne&Sam 2007 Safari 10 08-24-2016 01:41 PM
Stabilizer Bars 63 Safari donbara Hitches, Couplers & Balls 1 04-27-2008 07:33 AM
Tundra 4.7 vs. 5.7 for a 20' Safari marta5 Tow Vehicles 21 02-20-2008 11:17 PM
2008 20' Safari SE Jeff Evans Member Introductions 12 10-31-2007 07:08 PM
All New 2006 Safari 20' Colonial Airstream Commercial Listings 32 04-17-2006 11:44 AM
