Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2007 Safari SE
Old 05-12-2007, 08:08 PM   #1
Profile:  2007 25' Safari FB SE
Kennesaw , Georgia
Question Smoke alarm keeps 'alarming'...
Hey, our smoke alarm keeps going off at random; first time was at 5 a.m. two days ago, and it did it again this afternoon. Of course, there's no fire/smoke, and it has a brand new Duracell battery in it.
My theory is that the smoke alarm is getting very cold from the direct cold air blowing on it from the A/C unit. Perhaps this is setting it off?
Any ideas?
Thanx, Lance
TennisMan is offline   Reply With Quote
Old 05-12-2007, 08:38 PM   #2
CA Streamer's Avatar
Profile:  2005 28' Safari S/O
Atascadero , California
Lance, You didn't say what type of Airstream you have. Is it brand new?
Steve-- "Mongo only pawn in game of life"
CA Streamer is offline   Reply With Quote
Old 05-12-2007, 09:19 PM   #3
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Many times dust or a spider or other insect will invade, causing a false alarm. Blow it out (gently) with compressed air or vacuum it out. It sometimes helps. Sometimes they're just defective. On the plus side, they're also relatively cheap if it's not still under warranty.
Dave
Fyrzowt is offline   Reply With Quote
Old 05-14-2007, 08:48 AM   #4
Kennesaw , Georgia
Yeah, sorry, it is a brand new A/S 25 Safari SE FB; put a fresh battery in it as well.
Lance
Old 05-14-2007, 09:10 AM   #5
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Could be defective...... if you've replaced the batteries and blown out any dust and it's still doing it, a replacement (under warranty) might be your next step.
Old 05-14-2007, 10:35 AM   #6
SilverCabin's Avatar
Profile:  2007 23' Safari SE
Viera , Florida
Sensitive Alarm
I had problems with mine too this past weekend. I was cooking breakfast, eggs and sausage, nothing generating any visible smoke. All the windows were open, fantastic fan was on, range vent fan was on, and the darned thing kept alarming. I fanned it with a towel and it would go off. After a few cycles of that, I took it down and set it outside on the picnic table.
In my 23 footer, the smoke alarm is on the ceiling at the street side front, about eight to ten feet from the stove. Perhaps that is too close.
Randy
Randy and Pat Godfrey
2nd VP Florida Unit
WBCCI# 7591 - AIR# 17017
2007 Safari SE 23' - Daisy
2006 Lincoln Mark LT - Hoke
www.silvercabin.net
A journey of a thousand miles, begins with a cash advance--a big one this year
SilverCabin is offline   Reply With Quote
Old 05-14-2007, 12:15 PM   #7
jimmickle's Avatar
Profile:  Marion , Iowa
I have had two first alerts fail recently. If yours is first alert, call them at the number on the back. After a few questions to make sure that it isn't just a bad battery, they told me to buy a new one and send them the bill, and they would send a check. They did on the first bad one. I am waiting for the second check. (Its only been a week)
jimmickle is offline   Reply With Quote
Old 11-06-2007, 08:36 AM   #8
just jd.
5cats's Avatar
Profile:  2007 20' Safari SE
San Diego , California
Good suggestion!
Yesterday, our smoke detector began emitting the every-thirty-seconds-peep -- virtually one year to the day since we brought it home brand new. We replaced the 9V, tested fine. Then: peep...peep... Blew out the vent/casing (there's not much to these things): peep!
So I'm committed to replacement.
Molded into the casing:
  • Brand: Universal
  • Model: S8-775
  • Mfg Date: 2006JUN28
  • Replace by year: 2016
  • Phone: none listed
Oh well, home depot or costco for a cheap multi-pack.
Better yet, I may just replace this unit and the CO detector, mounted right next to each other, with a single multifunction detector.
Too bad the factory saw fit to mount the smoke detector directly on the ceiling panel of our SE, instead of the wardrobe side like the CO detector: screw holes in wood are easier to hide in wood versus the shiney AL panels!
Cheers,
-jd.
2007 20' Safari SE/LS // 12063 // xxxx
5cats is offline   Reply With Quote
Old 11-06-2007, 08:51 AM   #9
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
Originally Posted by 5cats
Good suggestion!
Cheers,
-jd.
We have twice had smoke detectors alarm for no reason - both time there were spider webs inside between contacts.
If you have to leave exposed holes in the aluminum, consider filling them with rivets. They will look intentional and at least be the same color.
77 Argosy Minuet, 6 metre
77 Argosy 24, Rear door
AIR 3181, WBCCI/VAC # 5575
Wally knows: AIRForums.com is the best place to camp!
Janet is offline   Reply With Quote
Old 11-06-2007, 08:59 AM   #10
just jd.
5cats's Avatar
Holes: perfect! and why didn't I think of that?
I just now completely disassembled the smoke detector to look for critters or anything, but found nothing. Still quite clean. I'll just replace it and have peace of mind.
Cheers,
-jd.
Old 11-06-2007, 11:35 AM   #11
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Last year I bought a First Alert 10-Year smoke alarm. It has a lithium battery, so you don’t have to change batteries for the life of the unit. After 10 years, just get a new one.
Vaughan
Old 11-28-2007, 02:40 PM   #12
billberk's Avatar
Springfield , Missouri
Lance,
We've had the same problem since day one. I think the things are just too sensitive to temperature change.
I hate to admit it, but we take the batteries out when we camp just to shut them up.
Bill
billberk is offline   Reply With Quote
Old 11-29-2007, 09:43 AM   #13
jzelle's Avatar
Profile:  2006 28' Safari SE
Orleans , Ontario, CANADA
Same here, just not practical in such a small space. We threw ours out on day one.
John
If you need to turn on your air conditioner,you've gone too far south!
2006 Safari SE 28W/LS,
2006 Silverado 2500HD/LT EC SB 4x4 Duramax/Allison,
Hensley Arrow , Honda EU2000i (propane),
160W Solar, 400W sinewave inverter,
3-stage smart charger, Xantrex battery monitor,
Sirius satelite radio
jzelle is offline   Reply With Quote
Old 11-29-2007, 10:14 AM   #14
Profile:  2007 30' Classic
Leonardtown , Maryland
Smoke Alarm
Smoke alarms are sensitive to ozone in the air, and in a small space noticable ozone may be produced by an electric motor. An example of a ozone producer is an electric drill. The sparks coming from the brushes cause ozone, not a lot but can be detected with smell. Im thinking maybe some loose wires around the Converter unit.
A CO sensor should be mounted near the floor because Carbon Monixide is heavier than air. If it is on he cieling and goes off noone will hear it. Too Late.
Just some thoughts and things to look for in the AS.
dale
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Pingbacks are On
Holy Smoke! Safari-Rick Batteries, Univolts, Converters & Inverters 4 10-06-2007 09:32 PM
Furnace sets off smoke alarm silverback 2003 International CCD 37 11-12-2006 08:24 PM
Smoke detectors BillTex General Interior Topics 7 07-19-2006 10:28 AM
smoke alarm frederic.c01 Interior Restoration Forum 9 08-06-2004 10:39 PM
Smoke Detector 1985air345 Airstream Motorhome Forums 7 09-02-2002 07:57 PM
SEO by vBSEO 3.1.0
