Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2007 Safari SE
Old 09-14-2007, 06:28 AM   #267
SilverGate
SilverGate's Avatar
Profile:  2007 23' Safari SE
San Diego , California
So, until our next trip up to the mountains in October…
Cheers!
SilverGate, Diego Flamingo, Larry, Pau Hoa and Corgi, Mac
Name:	HPIM1319 Cheers from  Surfer SilverGate.jpg
SilverGate is offline   Reply With Quote
Old 09-14-2007, 08:11 PM   #268
TBRich
Commercial Vendor
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
SilverGate...
As always, fun to read of your antics and to see how much you truly enjoy your Airstream on trips... And thanks for the tips you provide (both genreal and solar power related) as well...
Cheers back atcha!
TB
Old 09-14-2007, 09:22 PM   #269
mistral blue
Certifiable
mistral blue's Avatar
Profile:  1977 Argosy 24
Beautiful , New England
Mr. September
One of these days I've got to make a "Men of Airstream" calendar. (Now where the heck did I stash that one of Fred Coldwell....)
"IT'S A MAGICAL WORLD, HOBBES, OL' BUDDY... LET'S GO EXPLORING!" ~ CALVIN
mistral blue is offline   Reply With Quote
Old 09-18-2007, 07:19 PM   #270
trippy
Charleston , West Virginia
How did you hang the TV?
Jim Triplett
Charleston, WV
2007 Safari
trippy is offline   Reply With Quote
Old 09-19-2007, 03:44 AM   #271
SilverGate
SilverGate's Avatar
Factory-installed LCD Mounting Bracket
Jim (trippy) – Well, I didn’t hang the TV…
The LCD was mounted by the Airstream Factory during the build of the trailer on a peerless bracket attached to another bracket with accompanying Velcro straps and rubber bumpers. See:
http://www.peerlessindustries.com/dyn/Products/BrowseProduct.aspx/productId/149292/categoryID/195/u/T
Wires pass through the refrigerator wall and continue through the articulating arm.
(See my first post of this thread: http://www.airforums.com/forums/f396/silvergates-safari-home-last-29471.html, which lists more of the options that I selected when I placed my Factory Order. This LCD mounting is another good example of why, for some of us, it makes sense to order every option that you think you might want, use or need. Having the Airstream Factory install the options as an integral part of the trailer during the build is probably more economical in more ways than one. It will probably save you money, time and aggravation down the line… and it is covered in the two-year warranty.)
Placement of the bracket is important. Note that the bracket was placed just high enough to permit access to the recessed magazine storage rack, but not too high to cause neck strain when viewing LCD from Lounge.
Name:	HPIM1367 LCD bracket (peerless).jpg
ID:	45648  Click image for larger version
Name:	HPIM1371 LCD facing Lounge.jpg
Old 09-19-2007, 03:51 AM   #272
SilverGate
SilverGate's Avatar
The Airstream Factory also correctly mounted this bracket close enough to the corner edge of the wall to permit full 180 degree swivel so that the LCD can also be viewed from the bedroom.
Name:	HPIM1370 LCD bracket swiveled 180 degrees.jpg
ID:	45650  Click image for larger version
Name:	LCD viewed from bed.jpg
Old 09-19-2007, 03:58 AM   #273
SilverGate
SilverGate's Avatar
The bracket has a slim profile and notice the tilt of the LCD for comfortable viewing.
I utilize the input ports on the side of the LCD for viewing the day’s photo shoot directly from my hp camera while it is in its recharging dock.
This bracket is sturdy and securely holds the LCD with Velcro straps.
Mr. September (...thanks mistral blue)
Name:	HPIM1369 LCD bracket closed (profile).jpg
ID:	45652  Click image for larger version
Name:	HPIM1368 LCD secured by bracket strap.jpg
Old 09-19-2007, 09:52 AM   #274
FOILED
Formerly FreshAir44
FOILED's Avatar
Profile:  2008 23' Safari SE
Seattle , Washington
L-Shaped Couch to Bed
Silvergate:
Thanks for all the great postings here - not sure what I enjoyed more -- the valuable Airstream information or the cooking/camping inspiration
I have a question for you and I will see if I can explain this without pictures -- when you open up the L-shaped sofa bed, does it create a full rectangle on all sides or . . . does the pull out piece fall short of lining up along the edge of the couch closest to the cabinet (that holds the table)? In other words, I wish my pull out would go out about 4-5 more inches so that I can get a full rectangle bed?
Does that make sense? Just wondering if yours was the same . . . If so, have you checked into getting that to come out farther?
THANKS!!
FreshAir44
FOILED is offline   Reply With Quote
Old 09-24-2007, 02:53 AM   #275
SilverGate
SilverGate's Avatar
More Inner-Space Discoveries, Problems & Fixes
Well, I hadn’t planned on posting until our October mountain adventure.
But sometimes viewers’ questions lead to items of our 23’ Safari that warrant further elaboration and illustration.
Such was the case with trippy’s "TV" inquiry and most recently, FreshAir44’s L-Lounge question...
Or as some would say the groucho… err, gaucho question.
So this got me thinking…
Old 09-24-2007, 02:55 AM   #276
SilverGate
SilverGate's Avatar
The front L-Lounge (which has a gaucho element: the part that converts from a sofa to a bed), along with the nearby table with drawers and stow-away rolling dinette table, were one of the wonderful space-utilization features that attracted us to this Safari.
Name:	HPIM1393 Lounge opened (no bedding).jpg
Old 09-24-2007, 03:00 AM   #277
SilverGate
SilverGate's Avatar
The L-Lounge also makes for a pleasant area for indoor socializing. After completing several trips, however, we found that most of our socializing was done outside at the campfire or picnic table/folding table.
Repeatedly converting the lounge sofa, with its multiple cushions, into a bed and back into a sofa in such a tight space soon became a senseless bother and no fun!
The gaucho, in the opened position, with back cushions and extra pillows, beckons one to sit, relax, read, watch the LCD, or take in the view outside the door. While camped at South Carlsbad State beach, the door faced the ocean allowing a repeated, spectacular eye-level view from the gaucho of flocks of brown pelicans and other sea birds soaring by on the updrafts along the bluff. The opened gaucho is also a convenient area to secure small items while towing and is a great area to spread out materials/tools while working on a project (or flying kites).
Name:	HPIM1320 Larry & Mac relaxing.jpg
Old 09-24-2007, 03:06 AM   #278
SilverGate
SilverGate's Avatar
So I was happy that FreshAir44 just bought a 2008 23’ Safari SE with L-Lounge (Congratulations!) and had a question that I could answer.
And in my usual style, I went out to the trailer to take some photos to illustrate the answer:
The slide-out gaucho section extends the bed area width to about 45", which is about 6" shorter then the stationary street-side section. I would not try to extend the slide-out section more than it is designed to function for several reasons. One is that this cantilever design is designed to carry a certain weight over a specified distance. Making the distance longer could stress the metal glide rails and wooden support arms. And if the pullout section were 6" longer it would go into the door entry space.
Name:	HPIM1396 lounge opened (no bedding).jpg
Old 09-24-2007, 03:09 AM   #279
SilverGate
SilverGate's Avatar
Since I had taken off the bedding to take the last photo, and I couldn’t resist doing some more inner-space exploring.
Removing the street-side cushions revealed the hole
(pay no attention to those tools… that comes later!)
Name:	HPIM1386 Sub woofer hole.jpg
Old 09-24-2007, 03:11 AM   #280
SilverGate
SilverGate's Avatar
Through which the sounds of the sub-woofer, below, emanated…
Name:	HPIM1390 Sub-woofer.jpg
ID:	45925  Click image for larger version
Name:	HPIM1391Sub-woofer connections,controls.jpg
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
vetdr
2003 Safari 25 Melvin P. Thorpe 2003 Safari 24 09-15-2007 11:53 AM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 12:10 PM
'78 Argosy central heater motor home edmatlock Furnaces, Heaters, Fireplaces & Air Conditioning
