Starflyte1… Thank you for the kind note & glad you like the thread!
Antique Pedaler… Thank you for another good customizing idea!
Cutting-board note… supporting bracket is called a folding shelf bracket…
Found at Rockler Woodworking…
www.rockler.com
I’ll post an underside view tonight.
Bathroom door strap is actually webbing attached to bed frame with 2 screws…
And attached to door with a snap.
Malfunctioning Tappan Microwave wave replaced under warranty within a week.
(The turntable kept turning with fan and light on after food was removed & door closed)
Supplier InterCon Marketing sent the new one & it works fine.
Small leak from missing sealant over Vista View Window fixed...
See my fix and photos in Caulking & Sealants thread under Exterior Restoration:
http://www.airforums.com/forum...e-7626-11.html
Missing manuals… I received about 20 manuals, care/instructions in Delivery Case…
But missing at least another 20… Alan Wuebbenhorst, Airstream Customer Relations Rep is assisting me in getting the others, especially the important ones!
Atwood Hot Water Heater… although the Dealer Service tech mentioned during walk-through that it might be a good idea to get an anode rod to prevent corrosion… a quick look at our Atwood Water Heater manual and a call to the maker verifies that this would void their warranty! Which is another incentive to obtain and carefully read all manuals!
Cheers!
SilverGate
