Old 09-18-2017, 05:33 PM   #1
cashdaddy's Avatar
2007 25' Safari FB SE
Rocky Mount , Virginia
Mildew in back storage compartment
Ok, need to know what to do... the lesson has already been learned to store water hoses in totes so this is after the fact. In the back storage compartment water leaked out from a hose and sat several weeks before we knew it. Mildew of course set in on the carpet. I pulled the carpet and padding out. The wood underneath is pretty tender in two places but for the most part seems sturdy. It's the two places that have me concerned. One place I can push in on using a finger. What is a quick easy fix? Please tell me there is one.Click image for larger version
ID:	295164Click image for larger version
cashdaddy is offline   Reply With Quote
Old 09-18-2017, 05:47 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
http://www.homedepot.com/p/PC-Produc...4440/100649629
http://www.homedepot.com/p/Minwax-1-...0000/100376253
Sirs Gawain & Galahad
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 09-18-2017, 06:19 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
You may have water getting through the wall from the exterior. The lid on the rear bumper storage goes through the wall. It was not sealed at the factory when it was built. Unless someone has sealed it, by removing the rub-rail and caulking, it is something you should consider doing quickly.
It will get worse!!!
I know from personal experience!
http://www.airforums.com/forums/f456...de-109059.html
Alan
Old 09-18-2017, 06:38 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
That looks like a lot more water than would leak from a drained water hose. I suspect you have a major long term leak like Alan said. Open it up and let throughly dry, paint with a product like Kilz and find that pesty leak.
MICHAEL
Old 09-18-2017, 08:25 PM   #5
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Looks like what alen said. That's a leak. This will help
http://www.homedepot.com/p/Minwax-1-...210757&cj=true
Old 09-19-2017, 05:19 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Had the same problem with our Classic.....
After removing the carpet, cleaning & drying......Plastic drainage tiles in ALL storage compartments.
POI.....took a week of heat lamp & fan to dry.
Good Luck...
ID:	295187   Click image for larger version
ID:	295189   Click image for larger version
“Growing Old…being able to think about things you can no longer remember.”
RLC
“It’s a crooked piece of time that we live in….”
John Prine
"Tahawus"
Old 09-19-2017, 12:08 PM   #7
BradT
2007 27' Safari FB SE
Milton , Georgia
I agree that it looks like a long term leak from the lid on the rear bumper storage. It is a slow horizontal seepage leak via capillary action thru the sandwich of the frame, storage lid plate, and plywood.
I am just completing my repair that involved replacing plywood in that area. I was able to see where the water came in. The morning dew would puddle on the lid hinge plate every day.
Note that the obvious leak appears to be from the top of the lid hinge plate. It can also seep in on the underside of the plate. Water can get to the underside thru the hinge. There is no drip edge.
Notice the ends of the lid hinge plate are just sitting on top of the frame with the gap exposed. So caulk the exposed ends, and open the lid and caulk the seam all around the underside too.
If possible, check the underside of the plywood. If it has bubble foil "insulation" cut it away with a razor knife. The bubble foil traps moisture and encourages rot.
I would not seal the plywood. It is not supposed to get wet. If it does get wet you want it to be able to dry.
If the plywood has the factory black sealant paint around the edge, sand or scrape lines thru it to let trapped moisture out.
The factory water proofing design ended up creating traps for moisture instead of keeping it dry.
Last thing, spray the bare plywood with a 10% solution of Timbor to prevent further rot. Available from doyourownpestcontrol.com, Timbor is used on log homes and by utility companies to prevent power poles from rotting. Safe to mix and apply with a hand spray bottle, it makes plain wood become like pressure treated. It travels slowly via diffusion from cell to cell in the wood. It works great.
Good luck with your repair. It looks like only a small area and you caught it in time.
bradt is offline   Reply With Quote
Old 09-19-2017, 01:58 PM   #8
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
When the "Tin Can Shed" is in storage behind the house, I keep the Maxxe-Airrs" open, the interior doors, and cupboards open, and I have a small "Caframo" fan operating at all times. (The trailer is plugged into the house).
This helps to ensure that the air is moving all the time, circulating, and hopefully preventing mildew and mold.
In good weather, I may open a window to let in fresh air; in bad weather, the windows are closed.
Don't know what else to do.
MelGoddard is offline   Reply With Quote
Old 09-19-2017, 03:10 PM   #9
1975 31' Sovereign
West Liberty , Kentucky
We always connect the ends of our hoses together after draining them. Then the water does not leak into the storage compartment. I also open up the storage compartment and let it air out when we get home.
Air4563 is offline   Reply With Quote
Old 09-19-2017, 03:32 PM   #10
Boxite's Avatar
2008 22' Sport
Connecting the ends of the hoses does prevent leaks like that...but it also encourages bacteria growth. It's a good idea to run bleach-water thru them when you get home and let them air-dry.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 09-19-2017, 07:20 PM   #11
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Originally Posted by MelGoddard View Post
<<snip>>
Removing the lower rub rail and caulking the opening is the only semi-fix that I know of.
While in storage: I've started raising the trailer tongue an inch or two above level so that the bumper storage cover is slope away from the body. And, on one side the tires are on wood block an inch or two higher than the other side. Doing these thing help drain any surface water off the rear bumper lid quickly.
This minimal slope does not affect the function of the refrigerator or the AC condensate drain (at least on my trailer it does not).
Alan
Wires in back storage compartment Baked Potato General Repair Forum 4 03-26-2008 08:35 PM
Mold and Mildew and more. ojs_babydoll General Repair Forum 5 08-10-2005 11:34 PM
mildew dryan General Repair Forum 1 04-19-2005 06:08 AM
Need help with mildew yukionna General Interior Topics 1 07-26-2004 11:12 AM
MILDEW/solar ventilator Lexxy General Interior Topics 3 08-14-2003 09:26 AM
