Old 01-23-2007, 12:39 PM   #1
altamont's Avatar
2007 27' Safari FB SE
Tracy , California
Fantastic fan
Does anybodyknow if I can install another Fantastic Fan in the bedroom of my 27 FB SE LS without a lot of hassle? In short, is it prewired for power from the factory?
John
altamont is offline   Reply With Quote
Old 01-23-2007, 12:53 PM   #2
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Dealer should know...
Dealer should be able to answer that one, when addressing shower leak...
If not, another way to tell is check whether second fan was available as an option when trailer was built. If so, the wiring harness ought to be there.
As great as Fantastic Fans are, installs on Airstreams can be challenging (local Camping World sold us the fans, refused to do installs...) due to rounded surface and higher potential for leaks. If you do it, do follow up with Fantastic Fan company and get the curved inner plastic bezel (white or ivory color) which they'll often provide at no charge...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 01-23-2007, 01:24 PM   #3
SilverCottage's Avatar
LONDON , ON
We just ordered a 27 FB SE LS Safari with the second Fantastic Fan for April delivery. Although it is not listed on their mid-November option sheet (direct from customer service at AS) it is available as a factory installed option for about $250 so I assume the wiring would be there.
SilverCottage is offline   Reply With Quote
Old 01-23-2007, 01:26 PM   #4
Roadtoaster's Avatar
2019 30' Classic
Byhalia , Mississippi
John
I installed a FF in the front of my 2006 Safari and the wires were there. Pull the trim ring and feel all the way around the opening (on top of and underneath the insulation). Be careful of sharp edges!!! If the wire is there, the install won't take more than an hour including removing the old vent. If the wire isn't there, you should be able to tap a close ceiling light if a rib isn't in the way.
Good luck
Greg
Roadtoaster is offline   Reply With Quote
Old 01-23-2007, 01:39 PM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I had ordered ours with two and love it...you won't regret it.
As for it being pre-wired. I believe they use the wire from the light fixture near the roof vent. So, yes, it can be added.
Old 01-23-2007, 01:46 PM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have seen Fantastic Fans but don't know much about them. What's all the hubbub, bubb? What do people like about them? My 73 Sovereign and 71 Trade Wind have the original vents. No fans on the 73 but AC works.
Lumatic is online now   Reply With Quote
Old 01-23-2007, 03:25 PM   #7
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
John
John - You bet you can! We did it to our 22' Safari. In fact we installed a reversable unit so we have the option of the fan blowing out or in. In addition I installed a MaxiAir Vent Hood over it. So no matter the weather we can run the fan. It is also very good for leaving the vent open when traveling. All the wires are already there in place.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 01-23-2007, 03:46 PM   #8
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
John
I just put one in our 73 Overlander, check it out
Power_Vent
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 01-23-2007, 03:48 PM   #9
1992 34' Limited
Falls Church , Virginia
2nd Fantastic Vent in your TT
John -
Got a 2nd Fantastic Vent for SilverToy at Christmas. Naturally, the flat surround provided won't work exactly with the curved AS ceiling... called FV... they sent the correct piece for NO charge!!! It's going in as soon as Mother Nature calls of the constant snowfall here in the SW!!!
Use that "search" function in the upper right, plug in Fantastic Fan or Fantastic Vent, and there is LOTS including at least one install assist with loads of photos.... Can't go wrong!
Since you are, correctly, going with the FV - go all out and get the reversable/ rain sensor model. You can leave it open with NO worry whatever about moisture ( sudden shower, etc) getting into the trailer. With a front AND rear FV, one on IN and one on OUT - you'll have plenty of ventilation and air movement. You can even leave it open during transit!!! FV says so on the website!!
All the benefits, NO drawbacks! It doesn't get much better in today's world.
Axel
SilverToy
SilverToy is offline   Reply With Quote
Old 01-23-2007, 07:03 PM   #10
altamont's Avatar
Tracy , California
You guys are AWESOME!! Thanks.
John
Old 01-23-2007, 07:54 PM   #11
Aluminut
2004 25' Safari
. , Illinois
A number of us boondock. Unless you have a genset or shore power, no A/C, but the fans can work on standard 12v. I can get a wind tunnel in our Airstream with both on high.
Additionally, the company is legendary when it comes to customer service, even after many years of ownership, they stand behind it and more times than not, don't charge for the support or replacement part(s).
Old 01-23-2007, 08:28 PM   #12
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
They are a thermostat controlled fan with 3 speeds. They raise the cover either by 12 volt motor, or manually. They have an optional rain sensor so they close automatically if they sense rain. (Or other moisture like fog - this can be the down-side to the rain sensor)
The motors are reversable by switch so you can make them push air in, or out.
As mentioned, support is unsurpassed in my experience.
Dave
Fyrzowt is offline   Reply With Quote
Old 01-23-2007, 10:06 PM   #13
1992 34' Limited
Clarification!
All -
Dave, Thanks for the clarification on the FV features. I should have been more clear. You did it for me... for that, I thank You!
Anyone that opts for the "Ultimate" FV will, in very short order, realize that they invested in the "Ultimate, Unsurpassed, Utilitairian" wonder, - in short, the BEST!!! 2 FV's is even better!
Un-Surpassed!!!! Fit's FV to a tee. Product, Customer Service, support over the long term, fits that curved ceiling with the adapter....
Try it, You'll LOVE it!!!!
Axel
SilverToy
Fan-Tastic fan install Gordon Watt Roof Vents, Skylights & Fans 28 08-15-2011 12:41 PM
Loud range hood fan lbrodsky 2001 Safari 5 09-26-2003 07:08 AM
Larger Fan Blades in top Vent Sav'h Steve Roof Vents, Skylights & Fans 5 07-09-2003 06:35 PM
Exhaust Fan Cat Roof Vents, Skylights & Fans 1 10-04-2002 11:44 PM
Electric Cooling Fan Settings rdm Mechanics Corner - Engines, Transmission & More... 1 07-12-2002 07:29 AM
