Originally Posted by mikenicholso
Andy - Good suggestion and I have tried lubrication to no avail.
Clipper - Now that you mention it, the stabilizer do make it much worse. Too tight I guess. But it seems like they need to be that snug to stabilize the trailer.
Astroboy - where exactly did you place the washers?
Thanks all
Modifying the location of the lock in the door, is looking for trouble.
Adding washers within the hinges, is again, asking for trouble.
You can easily, move the striker pocket to solve the issue.
The stabilizing jacks, are exactly that. They should never be used to "lift", as that will cause them to break, or bend.
Cinching them firmly, to stop the shell from moving as you walk thru the coach, is all that they are designed to do.
