Bike rack mount
The PO of my '86 Sovereign had a U-channel welded to the frame and a receiver tube welded on. You can see that he had a steel strap formed to go over a PVC pipe which houses the sewer hoses and it was bolted to the rear bumper. It looks sturdy and he said that he had a couple of bicycles on a rack which fit into the receiver tube. I have some rear belly pan work I need to do because he obviously ran over something that dented in the rear pan a couple feet in front of the bumper.
Rather than leaving an open receiver tube, I had an aluminum 2" tube welded onto an aluminum plate to mount my 75th Anniversary license plate.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
