Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2007 Safari SE
Old 10-27-2009, 11:59 AM   #1
Commercial Vendor
Profile:  Corona , California
Originally Posted by dkottum View Post
Good points made by all. But if we want to hook up our Airstreams and go, Inland Andy's advice cannot be ignored. Experience is valuable and we are fortunate to have that input. Can we have the "soft" connection Andy recommends with the balance and stability needed for safety, and still have the reserve power to pull the long grades? Is it in suspension, the hitch arrangement, or are there other factors? We adore our new Airstream and are about to leave on an extended trip, so I guess we will learn as we go.
Doug and Cheryl
Doug.
A rule of thumb for what rating torsion bars to use is rather easy.
In your case, you don't have much tongue weight to start with.
If you have a 1/2 ton truck, use a 750 to 800 pound rating.
If you have a tow vehicle that's heavier duty than that, drop to 550 to 600 pounds.
Using a "torsion type" sway control, further increase the safety margin.
Friction type sway controls are not good in slippery road conditions.
What kind of tow vehicle do you have?
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 10-27-2009, 12:22 PM   #2
Profile:  2007 20' Safari SE
Battle Lake , Minnesota
Andy, we have a 2006 Tundra crew cab with 6800# towing capacity. The trailer is 4200# with 600# tongue wt empty. The dealer installed 1000# Equal-i-zer brand hitch because that is what they sell (next size down is 600# and the bars are not interchangeable from one weight to another), and at $700 each I am not too happy to change hitches. There seems to be a tradeoff here between bar tension for a "soft" ride and enough tension to have effective sway control. Equal-i-zer's method of adjustment is basically transferring enough load to the front wheels to keep the truck at the same level front and rear with the trailer on, as with it off, and maintaining a level trailer.
Old 10-27-2009, 12:58 PM   #3
Commercial Vendor
Goes to prove what I have said for years.
"Most dealers and especially sales people, don't have a clue" about load equalizing hitches.
What the dealer did to you, proves that point.
Drop the rating to 600 pounds.
Torsion bars "DO NOT" provide sway control. They transfer weight.
All you can do is lower the bar rating, and add a friction type sway control.
Or, and probably at additional money, install a dual cam Reese 600 pound rated hitch bars, and you would be doing the best that anyone could do.
Installing the Hensley, in your case, would further the problem you now have, since they do not have small rated bars, not to mention the cost.
Now, sit back and relax, and watch the "nay sayers" jump on this one.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-27-2009, 01:10 PM   #4
w7ts's Avatar
Profile:  2010 31' Classic
Longmont , Colorado
...............................................And y
The Equal-I-Zer has friction sway control built in. There is friction where the bars mount on the tongue and friction where the bars attach to the ball mount. You cannot change bar size on an Equal-I-Zer, you must buy a whole new hitch with different weight rating.
Regards,
Ken
w7ts is offline   Reply With Quote
Old 10-27-2009, 01:26 PM   #5
Commercial Vendor
Regards,
Ken
Ken'
Equalizer bars are attached to snap up brackets on the A-frame, with a chain.
How does that provide friction?
Also the end of the bars that are inserted into the ball mount, must be lubed.
Any remaining friction therefore, is very small, at the ball mount.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-27-2009, 01:44 PM   #6
w7ts's Avatar
Longmont , Colorado
Ken'
Hi Andy,
Go look a Equal-I-Zer's web site. The bars rest on brackets mounted to the tongue. when the hitch is adusted correctly there is significant fricton between the bars and brackets. the sockets where the bars mount to the head are also designed to provide friction as the bars swing left or right. I'm not a fan of the Equal-I-Zer, but that is how they say it works. I used an Equal-I-Zer on my previous TT, but use a ProPride on the airstream.
Regards,
Ken
Old 10-27-2009, 01:27 PM   #7
Kajendo's Avatar
Profile:  1983 31' Limited
Hope , British Columbia
Listen to Andy
1983 32' Limited. TV - 1996 3/4 ton Dodge 4x4 turbo diesel.
dual cam sway control
Hello Andy,
Your advice was taken to heart last year and we down sized the torsion bars from 1200 lbs. to 600, the ride for us is much softer and for the trailer much improved. My question. Should I change the ball mount as well? The trunnions are smaller but of course the chains keep them snug.
Time for 4 tires on the AS. What is AS putting on new trailers.
Jim Irwin
Hope BC
1983 31' Limited
Hope
British Columbia
Kajendo is offline   Reply With Quote
Old 10-27-2009, 01:39 PM   #8
Commercial Vendor
Hello Andy,
Jim Irwin
Hope BC
What brand hitch do you have? If it's a Reese, all the trunions are the same size that go into the ball mount. The different in size is the square hole for the bars.
Airstream switched to Goodyear Marathons, many years ago, and still use them today. Make sure you get the running gear balanced. If you can only get the tire and wheel balanced, there are other options available to complete the balancing setup.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-27-2009, 01:45 PM   #9
frlcad5's Avatar
Profile:  2000 28' Excella
Stewartstown , Pennsylvania
Thumbs up
I use a HAHA and it seems to me, though it uses 1200# bars you only preload them to where you need them by running up the jack screws. I have a tried several settings on them and have found my best setting. I now use a predefined setting each time with great results.
I bought my AS because I thought it was a much better trailer than the many many White Boxes I checked out. I still think that. There are times that I wonder why AS couldn't have done a better job but I'm that why with ever product I purchase. It seems to me that we find too much fault with our AS products and blame AS. I think this forum is best served helping each other when and where we can.
frlcad5 is offline   Reply With Quote
Old 10-27-2009, 12:36 PM   #10
Profile:  1977 31' Sovereign
McHenry , Illinois
Everyone one of the previous 28 posts is partially true. We just ran the African Capetown to Cairo Caravan movies at our weekend rally. The pounding those units endured and survived was outstanding. However, some did not make it all the way and neither did the heavy duty trucks they were using.
Current Airstreams are selling based on the legacy of their durability in the past. Airstream no longer has company sponsored caravans or engineering product support to fully test the durability of their product. The aluminum alloy the new trailers are made from is a higher strength but less corrosion resistant alloy. The old trailers in the African Caravan were made from 2024 with the T-3 treatment like they used in airplanes of that time. The new ones are made from 6061 also in the T-3 condition and is actually stronger than the 2024.
The trucks are no stiffer than was used on the caravan. I tried to see just what hitch bar system they were using but could not determine this from the fussy pictures. Dale might be able to tell you better, since he is the only person I know of that was on the caravan and is still associated with WBCCI.
Despite their big reputation, Airstream is actually a very small company with a very limited budget for true structural engineering and testing. Ford and GM are much more sophisticated large companies and unbelievably are also in poor financial condition. They do own large test tracks to test the durability of their products. We, the customers, are now serving Airstream as their product durability test team. If they do not listen to the results of our testing and improve their product as the result of our testing, then their reputation and legacy will be lost and they will have a more difficult time marketing that legacy in the future.
Old 10-27-2009, 12:46 PM   #11
1 Rivet Short
Profile:  1989 25' Excella
By The Bay , Rhode Island
The rating of the hitch bars is irrelevant. The load you place on them (preload, tension…choose the term you like most) is the important factor. “Proper” hitch setup is what matters. This whole theory about heavy duty tow vehicles causing damage to AS frames…did anyone tell Wally?
Life is Good-Camping all around New England
Good people drink good beer-Hunter S Thompson
BillTex is offline   Reply With Quote
Old 10-27-2009, 01:22 PM   #12
cameront120's Avatar
Profile:  1972 25' Tradewind
Shouldn't instructions for correct towing setup come from the factory with each trailer purchased?
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
cameront120 is online now   Reply With Quote
Old 10-27-2009, 01:31 PM   #13
Commercial Vendor
Nope.
The one word answer, is "LIABILITY".
There are way to many ways for someone to sue the manufacturer, for lack of a coma in the right place, or an I not doted, etc.
The second reason being, the manufacturer could "NEVER" get away with telling you what tow vehicle you must buy.
Bottom line. Attorneys would get rich over things like that.
Sorry, but that's the way it is.
Shoe manufacturers, would never tell you where not to walk with their shoes, either.
Many things in live are governed by our individual choices, therefore we, as the consumer, must accept responsibilty.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-27-2009, 01:41 PM   #14
Profile:  2004 30' Classic Slideout
. , Kentucky
Weight Distribution Bars
Does tongue weight have anything to do with what size weight distribution bars to be used? I have a 30' SO with an empty tongue wt of 1125#. The trailer gross wt is 9100# and newer models gross at 10000#.
fltlevel510 is offline   Reply With Quote
