Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2007 Safari SE
Old 10-30-2009, 02:00 PM   #141
tpi
Profile:  2005 25' Safari
Trabuco Canyon , California
Have you heard back from Jackson center regarding your problems?
tpi is offline   Reply With Quote
Old 10-30-2009, 07:48 PM   #142
Profile:  2007 27' Safari FB SE
McKinney , Texas
I had to call them and their response was nothing more than "you are out of warranty sorry. We can't tell if you had you rig or hitch setup correctly or not or if there was something else that you may have caused." These were not exact words from them, but you can see Andy's quotes here which very much duplicate the words that were given to me over the phone.
Krazyjohnny is offline   Reply With Quote
Old 11-02-2009, 01:47 PM   #143
Airstream01's Avatar
Profile:  2008 25' Safari FB SE
Freetown , Undisclosed location
Krazyjohnny. That stinks man. I am going to the Mothership around the middle of December mainly just to see the place, stay at the tera port, etc, as I don't have any issues that need warranty work just yet. If I get a chance, and the nerve, I will ask them about their lack of customer service to those that are having what I consider pretty serious issues with nearly new trailers.
Airstream01 is offline   Reply With Quote
Old 11-02-2009, 02:32 PM   #144
Profile:  Corona , California
You might as well start at the "top" of the list.
Ask for Dave Schumann, when your at the service department.
You can also call ahead and make an appointment with him.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-03-2009, 05:20 AM   #145
Thanks Andy. I think Dave is the individual that called me last week regarding my comment card/survey I sent them after I bought my trailer.
Edit-it was Jim ??? that called me. I plan to call him back this morning.
Old 11-03-2009, 06:27 AM   #146
You must have talked to Jim Parrot.
He is a well informed, knowledgeable, very nice person, that has been around Airstream for many years, and is in charge of warranty Customer Service.
He works directly under Dave Schumann.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-03-2009, 06:51 AM   #147
McKinney , Texas
Jim is the guy my service folks have been dealing with. I called him directly and spoke with him. He is a nice guy. No complaints about his demeanor at all. Their policy is the stinker. They got my 50 large and seem to left me on my own. Everyone here has been extremely helpful.
The owners manual needs some serious updating and editing to the specifics of each trailer model. I have heard just in this string about running gear balancing, tires, suspension of the trailer, suspension on the TV, hitching, type of tow vehicle, etc. that could have caused the problem I am having repaired. Some of this is mentioned in the manual but nothing on details on some of this stuff. Ther was info on caster and camber of the axles, tire maintenance, wheel bearing packing, hitch heights, and washing and waxing the trailer.
Old 11-08-2009, 06:52 AM   #148
Kajendo's Avatar
Profile:  1983 31' Limited
Hope , British Columbia
What brand hitch do you have? If it's a Reese, all the trunions are the same size that go into the ball mount. The different in size is the square hole for the bars.
Airstream switched to Goodyear Marathons, many years ago, and still use them today. Make sure you get the running gear balanced. If you can only get the tire and wheel balanced, there are other options available to complete the balancing setup.
Hi Andy,
The photos should show the difference in size of the trunions on my 600# Reese dual cam anti sway bars. Should I take up a link on the small trunion?
After I switched out my 1200# bars the ride in our 3/4 ton 4x4 softened and the trailer floats along the hi-ways (except I-5's concrete washboard north of Seattle) compared to the ride with the 1200# bars.
ID:	90523   Click image for larger version
1983 31' Limited
Hope
British Columbia
Kajendo is offline   Reply With Quote
Old 11-08-2009, 07:02 AM   #149
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
Reese says the magic number is 5 links
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Defendwally.org
Old 11-08-2009, 10:38 AM   #150
1 Rivet Short
Profile:  1989 25' Excella
By The Bay , Rhode Island
Originally Posted by Kajendo View Post
Hi Andy,
Jim, you would have got the same effect decreasing the tension (load) on your 1200# bars. The rating of the bars is irrelevant. The force that you transfer is what is making the difference; 400# of force transferred with 600# bars is the same as 400# of force transferred with 1200# bars...
Only your wallet would still be heavier...
Life is Good-Camping all around New England
Good people drink good beer-Hunter S Thompson
Driver only carries $50...worth of ammo.
BillTex is offline   Reply With Quote
Old 11-08-2009, 11:17 AM   #151
Silver Mist
LI Pets's Avatar
I would disagree, the sping loading of the bars are very different.
WBCCI
Defendwally.org
Old 11-08-2009, 11:44 AM   #152
You would "NOT" have gotten the same effect.
You would not have transfered the proper weight to the front of the tow vehicle.
A proper rated hitch, must be properly installed, "AND" properly adjusted, for the purpose intended.
The rating of the bars is "everything".
Violated anyone of those and the hitch torsion bars, will not do what it's supposed to do.
The end result of that might be, what you hope will never happen to you or your Airstream.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-08-2009, 06:14 PM   #153
emdubyadee's Avatar
Plano , Texas
Same damage on my trailer
Originally Posted by Krazyjohnny View Post
All,
The more I research this the more it sounds like it could be filed as a Class action, especially since this has been well documented and known for at least 2 model years prior to mine and there were no design changes made.
Just FYI, I checked my trailer after seeing your pictures and found identical fractures. I'll be following this thread--please keep us updated.
~ Mark
emdubyadee is offline   Reply With Quote
Old 11-12-2009, 03:47 PM   #154
McKinney , Texas
emdubyadee,
We should get together sometime and make a you tube video. Maybe that would get some attention. The whole spring bar thing is totally baffling to me. Kind of like quantum mechanics and "anti-matter". Distribution of weight is distribution of weight. The size of the bars shouldn't matter as long as you do not use the bars to their complete rated capacity.
Andy,
You or Airstream got some splainin' to do. (in my best Ricky Ricardo voice)
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
A-Merry-Can, osolow
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
