Originally Posted by adwriter73
I'm looking at doing the same thing. Thought maybe the easiest option would be to wire the inverter to the battery and then plug in an extension cord to run anything off of it. Not ideal. But I would love to know how to wire it into the 120 system so that all plugs would have power.
You need to be careful with trying to energize all the 120v plugs with an inverter. You could end up with a battery-killing loop where you're energizing the converter from the inverter which itself is supplied by the batteries, so you'd run down your battery if the inverter is on, even if it has no apparent load.
I think it's a better idea to have dedicated inverter receptacles.
