09-28-2010, 10:23 AM
#41
Lisle
Almost done putting in the 100+ elevator bolts in the floor!!
I need some help. I have no information or photos of the rear floor at the service center. I need to know how that section goes together. It looks a lot different than my 1967. Any photos and information would help greatly.
Thank you
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
09-28-2010, 11:04 AM
#42
1967 26' Overlander
Winston Salem
, North Carolina
Hi,
I scanned a pic of the Service Center from the Owner's Manual.
In 68 the battery is in the rear, which I feel adds too much weight.
Keep up the great work....
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
09-28-2010, 11:44 AM
#43
Lisle
Greg,
That is a better image than my copy of the manual! Thank you.
I need to get a photo looking down into the service center. I need to see what the floor looks like in there. My trailer had no wood back there when I purchased it.
I am moving the battery to the front up under the gaucho. I want to remove as much weight from the back as possible.
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
09-28-2010, 12:00 PM
#44
1977 Argosy 24
Milltown
, Wisconsin
Make sure the battery is vented to the outside. Floor looks great.
09-28-2010, 04:12 PM
#45
Hendersonville, NC
, North Carolina
Pictures
Here's some photos I took when I was gutting our 68 overlander. Hope it helps.
Pat
09-28-2010, 07:23 PM
#46
Lisle
Pat,
Do you remember how it was bolted together under the drain pipe that runs across, under the door?
Tedd
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
09-28-2010, 07:33 PM
#47
Lisle
Took a break from floor bolts. Today was rivet day!!!! Wow buck riveting is wild!!! Lori and I really got the hang of it, just as the last few rivets went in.
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
09-29-2010, 07:03 AM
#48
Hendersonville, NC
, North Carolina
Floor drawing
Not much of mine was left at the very back. The piece of steel under the bottom had totally rusted apart on the right side. I (had) welded a new piece of steel in its exact same place however it was a little to the front. I drew an expanded drawing of what I did. Not shown is a rubber gasket from a garage door I put in there to help with water coming down the back.
Hope this helps,
Pat
09-29-2010, 07:52 AM
#49
Lisle
Beautiful!!! That is just what I needed. YEA!!!! Thank you Thank you!!! Now I can finish up.
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
09-29-2010, 08:53 AM
#50
Hendersonville, NC
, North Carolina
Under floor photo
Hi Till,
This shows the replaced steel brace with elevator bolts coming through from floor above. A thin original strip of aluminum is over that which I buck riveted a new aluminum hinge to.
PIANO HINGES from Aircraft Spruce
Top of the steel has POR-15 on it and the bottom will be POR'd later.
Over the aluminum strip is a garage door gasket which compressed nicely.
I made up all the hinge stuff before bolting the floor down.
Enjoy,
Pat
09-30-2010, 08:21 PM
#51
Lisle
Big progress over the past couple of days!!!
Thanks to Pat the back end is all buttoned up.
Riveted the wheel wells to the skin. Wow did that make a big difference in the feel of the trailer! finally started to put the interior skin back in!!! Yea!!!!
I have to say a pneumatic rivet gun is the way to go with the interior.
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
10-04-2010, 08:12 PM
#52
Lisle
The saga continues.....
Big step today. The rear end-cap was changed out. Yea!!!
Went from yellow to turquoise. I would not recommend this for the faint of heart. This was an interesting job in part because I changed a 1968 Ohio built Overlander yellow end-cap for a 1967 California built Ambassador turquoise one. All of this with the ceiling still in.
Took about 3 hours. BTW that is my 15 year old son with me. I need to put a brick on his head! He just keeps growing....
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
10-11-2010, 06:07 PM
#53
Lisle
Lots has happened.
Interior walls are up, 110 VAC is in and we went camping!!!
The aluminum tent was great
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
10-11-2010, 06:10 PM
#54
Lisle
Camping in the "tin tent"
First trip.
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
10-11-2010, 06:49 PM
#55
1964 17' Bambi II
Schererville
, Indiana
Now THAT looks like fun! Your kids will always remember that camping trip!
Becky
1964 Bambi II
1988 Avion 32S
10-23-2010, 11:17 AM
#56
Lisle
Been a little while since my last up date. I have suffered a set back at this point. Last weekend while engaged in my other hobby I was injured. Friday the 15th I received 11 stitches in my left thumb. Not good enough though, Saturday the 16th I managed to get my right hand mashed pretty bad. Luckily no broken bones, but it felt like it.....
Now with the cold damp weather, I am not sure how much progress will happen on the outside.
I plan on removing and cleaning/repairing the interior parts from my '67 to prep for assembly work over the winter/spring.
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
10-25-2010, 01:13 AM
#57
1967 22' Safari
MILAN
Hey now!
Tedd, That's not right! Changing out parts from one to the other trailer is one thing but trying to get new hands by cutting and squishing is very much another! Hope you get healed up soon and get back to the trailer updating. I don't think anyone will find fault with all the work you've done so far. Great job getting the wiring in and going camping. It will be great when the interior from the '67 gets into an updated shell even if it is a '68. Just think how nice it will be once all that work is completed and you can camp in real comfort with a trailer you know inside and out has been so carefully restored and updated. Keep us all up to date on all you are doing with lots of pictures and all the how to's! Carol and I hope to see the finished product real soon. Maybe when yours is done I can finally get mine on the road too! Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
01-02-2011, 05:52 PM
#58
Lisle
Well with the winter weather, I have turned to planning for the spring work. I have found that I can not use the gaucho that I made for the '67. The water tank on a 1968 is lower and wider.
Is there anyone with photos of a gaucho for a 1968 that show it's construction?
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
01-06-2011, 06:21 PM
#59
Hendersonville, NC
, North Carolina
Gaucho Base Photos
Hi Tedd,
Here are some photos I took this afternoon... more to come.
Pat
01-06-2011, 06:28 PM
#60
Hendersonville, NC
, North Carolina
...more photos of gaucho base
